[Review] Procase (Chieftec) SNT-2131 SATA Backplane
  • 12.536 views sinds 30-01-2008
  • tHe_BiNk
tHe_BiNk
He's evil! Very EVIL!
I could not find a review of the Procase (Chieftec) SNT-2131 SATA Backplane Raid 0,1,5 (this is the smaller brother of the Procase (Chieftec) SNT-3141 SATA), so I decided to write one myself. The review will be in English so all people who get here from Google can read it.
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-001.jpg
I purchased the SNT-2131 for alternat.nl for about 120 euros including P&P, a bit steep, you can get one from Denmark for a lot cheaper, so Google around.
My goal is to use the SNT-2131 for offsite backups. Two of the three HD’s will be offsite at all times containing backups of the two previous weeks (we use the integrated backup software in windows, as this is more than adequate for us).
The setup of our fileserver:
OS: Windows XP SP2, Multi Language
Motherboard: Asus A8N-SLI Deluxe (SATA controllers the onboard nVidia nForce4 (0,1,1+0) and the additional onboard Silicon Image Sli3114R (Raid 0,1,1+0,5)
HDs in the SNT-2131: 3X Hitachi Deskstar 7K250, 250GB, 7200rpm, 8MB, SATA150
WWW address of the product itself: http://www.chieftec.de/?p...id=215&k_id=4&language=uk
What does the package contain? The unit itself, a two page manual (the same as the PDF on their site), and three long SATA cables, around 100 cm.. The cables are much more flexible and softer compared to the ones you get when you buy an Asus motherboard. The case is made from aluminum, and the handles on the front and the backplate from plastic. The aluminum parts look and feel good, but the plastic parts look cheap and not too sturdy. The locks are pretty useless, because if you press hard the bay will open even the bay is locked
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-006.jpg
The aluminum sides have very few screw holes, and therefore does not allow for many different mounting positions, as you may want to allow it to stick out of the front of your PC, when space inside your PC is limited.
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-002.jpg
I opened the back op the SNT-2131 and flipped the fan (your basic 80mm fan, to which you could easily connect a fan controller), you need to unscrew six screws and will probably lose your warranty. Now the fan blows the air out of the front instead of the back of the SNT-2131.
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-004.jpg
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-005.jpg
The unit has two sets of jumpers on the back. On set sets the temperature of the overheating buzzer, and what the other set does is not known.
Afbeeldingslocatie: http://www.xs4all.nl/~dbinken8/pics/2131-007.jpg
I will update this review in the coming weeks, when I get the HDs. If you have any questions let me know.
/edit
June 2006: Well I see I never updated this review. I have been using this device for many months now, without any problems. Just be careful with the cheap plastic handles!
[ Voor 9% gewijzigd door tHe_BiNk op 04-06-2006 19:30 ]
APPLYitYourself.co.uk - APPLYitYourself.com - PLAKhetzelf.nl - Raamfolie, muurstickers en stickers - WindowDeco.nl Raamfolie op maat.
  • Shuriken
  • Laatst online: 14:24
Shuriken
Life is all about priorities
Nice to see a review :) even better to see you can replace the fan quite easily.
Hate to say this, but at www.4launch.nl it would have cost you 77 euro's. The 4 disc version goes for 100 euro's.
I rather have a bottle in front of me, then a frontal lobotomie
  • One_Gandalf
  • Laatst online: 16:02
I have bought this same device and the fan makes an aweful lot of noise.
Producer : Titan
Model : TFD-8020H12C
Voltage : 12 V
Current : 0.18 A
Watt : 2.16 W
RPM : 3000
CFM : 35.45
mm-H2O : 2.8
dBA peak : 31 dBA
This fan can't be easily replaced because of it's awkward dimensions of 80 x 80 x 20 mm.
  • John2B
  • Laatst online: 16:40
John2B
I Love RAID5..!!
All the DriveCages from:
Chieftec
Procase
Addonics
StorCase
Are made by Kingston, not that it matters, but good to now ;-)
A friendship founded on business is better than a business founded on friendship
I'm also using one of those for my Linux server RAID. I modified the case, however, to reduce noise. I completely removed the fan, opened up the full circular hole in the back cover, mounted a VERY quiet 120mm Papst fan to the rear of the computer chassis and lead a normal flexible ventilation air duct from the hole in the disk box casing to the fan and tightened with weave tape.
Measurements with hddtemp shows an increase in temp on the disks with one degree (C) at no or low load and two degrees at heavy load. The top and bottom discs are two degrees warmer than the middle discs, probably due to better air flow in the middle, but that was so also with the fan.
Now I have normal disk temperatures of 39 - 41 C.
/PjK
  • BalusC
BalusC
Carpe diem
The_Bink, zou je in het vervolg maar gewoon reviews in het Nederlands willen schrijven? :) Als je het per-se in het Engels wilt doen, bouw dan maar een website of post het in een andertalig forum.
