Microsoft VBScript runtime error '800a0009'
  • 116 views sinds 30-01-2008
  • ColdDog
ik krijg deze fout:
Subscript out of range: '[number: -1]'
/publicaties/index.asp, line 150
ik weet echt niks van asp, maar ik moet het oplossen. Heb al gezocht op GOT en heb niks gevonden wat mij kon helpen? Iemand een idee?
line 150 = currentcolor = colorarray(varimage-1)
ASP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Dim varimage, varcolor
'number of images
varpages = 0
'randomize the image
Randomize
While not rsPublicatieSelected.EOF
varpages = varpages + 1
rsPublicatieSelected.MoveNext
Wend
rsPublicatieSelected.MoveFirst
varimage = int(Rnd()*varpages)
rsPublicatieSelected.Move(varimage)
'check the string
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Outdoor") > 0)Then varimage=1
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Kids") > 0)Then varimage=2
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Sport") > 0)Then varimage=3
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Business") > 0)Then varimage=4
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Buyer") > 0)Then varimage=5
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Surf") > 0)Then varimage=6
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Tendens") > 0)Then varimage=7
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Snow") > 0)Then varimage=11
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "Snowboard") > 0)Then varimage=8
if(inStr(rsPublicatieSelected.Fields.Item("PublicatieTitel").Value, "SBC") > 0)Then varimage=9
'select bg color matching the image
colors = "#972929;#9700FC;#003296;#666666;#FF9900;#0092F3;#006400;#37B5FF;#666666;#37B5FF;#37B5FF;#37B5FF"
bgcolors = "#972929;#9700FC;#003296;#CCCCCC;#FF9900;#0092F3;#006400;#93D7F;#CCCCCC;#93D7F;#93D7F;#37B5FF"
magazines = "OUTDOOR MAGAZINE;KIDS MAGAZINE;SPORT PARTNER;BUSINESS GUIDE;BUYERS GUIDE;SURF 'N BEACH;TENDENS;SNOWBOARDER;SBCCATALOGUS;SNOW;SNOW"
magAbr = "OUTDOOR;KIDS;SPORT;BUSINESS;BUYERS;SURF;TENDENS;SNOWBOARD;SBC;SNOW;SNOW"
colorarray = split(colors, ";")
bgcolorarray = split(bgcolors, ";")
currentbgcolor = bgcolorarray(varimage-1)
magazinearray = split(magazines, ";")
currentmagazine = magazinearray(varimage-1)
magAbrarray = split(magAbr, ";")
currentAbr = magAbrarray(varimage-1)
[ Voor 11% gewijzigd door ColdDog op 18-01-2005 10:47 ]
  • Creepy
  • Laatst online: 00:32
Creepy
Tactical Espionage Splatterer
Ho ff, zo werkt het niet niet.
Hier wordt van je verwacht dat je eerst zelf actief opzoek gaat naar een oplossing. Daarnaast kunnen we met je foutmelding niet zoveel want ik zie geen regel 150 :)
Als je P&W Beleid eens door zou willen lezen dan graag :)
Bekijk daarnaast ook eens P&W FAQ - Algemeen . Code debuggen is ook iets wat je zelf zou moeten kunnen.
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
