i need help to overclock my cpu! (i59600kf)
  • 484 views
  • Tweak3r28
  • Registratie: Juni 2019
  • Laatst online: 04-06-2022
Hello everyone,
I recently bought a new PC from someone and these are the specs:
i play on 144hz monitor, MSI optix G241
cpu: i59600KF
motherboard: gigabyte z390 Aorus Pro Wifi
2x8GB Hyper X fury predator RGB 3200 MHz
GPU: Nvidia GTX 1050 TI cerburus 4GB
cpu cooler: Enermax liqimax 240 RGB
i have like 8 fans around the compenents
RGB Auorus SSD 265 GB
Power supply: Aero cool luxx plus RGB 650W
Im just curious if my CPU works well also. The PC is as new so i hope everything works well.
I'd like to overclock my CPU since its on stock 3,7 Ghz, i'd like to boost it up a little bit @ gaming in CSgo, and some other FPS games. So im curious on how far i can push this CPU to and how the temperatures will remain. So if there is someone that can help me out on how to properly overclock this CPU i'd really appreciate it.
Some i59600KF seem to be reaching 5Ghz but yea i guess ill start slowly and i'd already be happy with like 4,8 ghz to start with.
I have uploaded some pics of my BIOS and i have tested a few things, for example i pressed the Enhanced Multi Core performance and putted enable, so it would run all cores, and it did run @ 4600 MHz i saw, i did not touch anything else like the voltage etc. The only negative part it reached like 86degrees on CSGO and it seems like it was too hot. I gamed on it for like a hour and then turned it back to normal.
So the voltage was like on picture BIOS 6, except that i enabled the Enhanced multi core performance. and seems to be reaching very high temps in CSGO.
My question now is should i have adjusted the Voltages aswell or was this a normal move what i did? im ofcourse not a experienced overclocker so im not sure what im doing :)
Also on the bios on the first option i can adjust the CPU Upgrade to Default, Gaming, Advanced, on default its 3,7, gaming 4,3, advanced 4,6
Should i be changing my voltage if i do this? or does this gigabyte mobo do that automatically?
I have uploaded pics aswell bios1 to 6
[Voor 36% gewijzigd door Tweak3r28 op 17-11-2021 06:37]
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
