  • 0Henk 'm!
  • Saartjedeteckel
  • Registratie: Oktober 2019
  • Laatst online: 26-09 19:11
Ik heb een Galaxy note 9 en ik probeer lineage os erop te krijgen. Modelnummer is SM-N960F/DS.
Ik heb het volgende gedaan:
Linux: Extract the Heimdall suite zip and take note of the new directory containing heimdall. Now copy heimdall into a directory in $PATH, a common one on most distros will be /usr/local/bin. For example cp heimdall /usr/local/bin. You can verify Heimdall is functioning by opening a Terminal and running heimdall version.
Power off the device, and boot it into download mode
Now, click the button that the on screen instructions correlate to “Continue”, and insert the USB cable into the device.
On your machine, open a Command Prompt or PowerShell (Windows) window, or Terminal (Linux or macOS) window, and type:
heimdall print-pit
If the device reboots that indicates that Heimdall is installed and working properly. It is rebooting.
Download a custom recovery - i have downloaded the laatst Lineage Recovery.
heimdall flash --RECOVERY <recovery_filename
A blue transfer bar will appear on the device showing the recovery image being flashed. I get a bar failed so i think it is flashed right.
Unplug the USB cable from your device.
Manually reboot into recovery, this may require pulling the device’s battery out and putting it back in, or if you have a non-removable battery, press the Volume Down + Power buttons for 8~10 seconds until the screen turns black & release the buttons immediately when it does, then boot to recovery:
Bovenstaande dus allemaal gedaan en als ik nu in Recovery mode kom krijg ik de volgende opties:
- reboot
- apply update
- factor reset
Maar wat moet ik nu doen? Ik neig naar apply update maar dan is mij niet helemaal duidelijk wat ik dan moet doen.
Moet ik dan onderstaande handleiding volgen
Installing LineageOS from recovery
Download the LineageOS installation package that you would like to install or build the package yourself.
Optionally, download additional application packages such as Google Apps (use the arm64 architecture).
If you are not in recovery, reboot into recovery:
With the device powered off, hold Volume Up + Bixby + Power. When the blue text appears, release the buttons.
Now tap Factory Reset, then Format data / factory reset and continue with the formatting process. This will remove encryption and delete all files stored in the internal storage, as well as format your cache partition (if you have one).
Return to the main menu.
Sideload the LineageOS .zip package:
On the device, select “Apply Update”, then “Apply from ADB” to begin sideload.
On the host machine, sideload the package using: adb sideload filename.zip
(Optionally): If you want to install any additional add-ons, repeat the sideload steps above for those packages in sequence.
NOTE: If you want Google Apps on your device, you must follow this step before booting into LineageOS for the first time!
Once you have installed everything successfully, click the back arrow in the top left of the screen, then “Reboot system now”.
Ik hoop dat iemand mij kan helpen.
[Voor 0% gewijzigd door rens-br op 18-05-2020 08:08. Reden: Post leesbaarder gemaakt]
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
