• theduke1989
  • Laatst online: 29-09-2021
Mede-auteur:
  • Kiswum
  • Laatst online: 17-06 11:57
Kiswum
Xiaomi Redmi Note 3 (MediaTek processor) Ervaringen & Discussie Topic
Inleiding
The full metal #RedmiNote3 brings premium to a whole new level with its fingerprint sensor and massive 4000mAh battery. It houses the flagship Helio X10 processor and 13MP/5MP cameras while staying 8.65mm thin, 164g light - only 4g heavier than Redmi Note 2. Best of all, it has all your ideal flagship specs.
Foto's
Specificaties
OS:Miui7
Scherm formaat:1920 x 1080 pixels, 5,5" (~403 ppi)
Scherm type:IPS LCD capacitieve touchscreen, 16M kleuren
Multitouch:10 vingers
MediaTek versie (DualNet):
Chipset:Mediatek MT6795, Helio X10
CPU:Cortex A53 (64bit), Octa-core 2,2 GHz
GPU:PowerVR G6200 550/700MHz
3G Netwerk:WCDMA 850/900/1900/2100 MHz
4G Netwerk:FDD-LTE 1800/2100/2600 MHz (B1 / B3 / B7)
Camera (achterkant):13 MP (16:9), F2.2 aperture, autofocus, dual-tone LED verlichting, PDAF 0,1 seconde focus
Camera (voorkant):5 MP (16:9) 2560x1440 pixels, 4x digitale zoom, , F2.0 aperture
Qualcomm versie (FullNet):
Chipset:Qualcomm Snapdragon 650
CPU:Cortex A53 + A72(64bit), Hexa-core 4 x 1,8 GHz + 2 x 1,2 GHz
GPU:Adreno 510
4G Netwerk:FDD-LTE 850/900/1700/1800/1900/2100/2600 MHz (B1 / B2 / B3 / B4 / B5 / B7 / B8)
Camera (achterkant):16 MP (16:9), F2.0 aperture, autofocus, dual-tone LED verlichting, PDAF 0,1 seconde focus
SD card:Nee
Opslag geheugen (ROM):16/32 GB
Werkgeheugen (RAM):2/3 GB
Luidspreker:1 luidspreker
Simkaart:Dual-SIM, dual standby (2x Micro)
WLAN:Wifi 802.11 a/b/g/n/ac op 2,4GHz en 5GHz, wifi Direct, DLNA, wifi hotspot
Bluetooth:v4.1 Low Energy
NFC:Nee
Vingerafruklezen:Ja
USB:USB 2.0 (MHL), USB On-the-go
Sensoren:Snelheidsmeter, afstand, gyroscoop, nabijheid, kompas, licht, infrarood afstandsbediening
GPS:GPS, A-GPS, GLONASS, Beidou
Formaat:150 x 76 x 8,5 mm
Gewicht:164g
Accu:Niet-verwisselbare Li-Ion 4000 mAh accu
Kleuren verkrijgbaar:Goud, Zilver, Grijs
Led kleuren:Blauw, Rood, Groen, Oranje, Geel, Cyaan, Wit en Violet
Prijzen
De prijzen variëren van €125,- voor de 2GB MediaTek variant tot €167,- voor de 3GB Qualcomm variant.
Europeanen kunnen hun telefoon nog niet rechtstreeks bij Xiaomi kopen, dat gaat via een reseller/internationale webshop. In de praktijk zal de prijs vanaf €150,- beginnen voor het standaard model en het Prime model zal rond de €250,-liggen (excl. verzendkosten en eventuele importkosten).
Note 3 Standaard (Dual Netcom met MediaTek processor): 899 Yuan
Note 3 Prime (Dual Netcom met MediaTek processor): 1099 Yuan
Note 3 Standaard (Full Netcom met Qualcomm processor): 999 Yuan
Note 3 Prime (Full Netcom met Qualcomm processor): 1199 Yuan
Dual Netcom ondersteunt twee Chinese providers: China Mobile en China Unicom.
Deze telefoon zal altijd een MediaTek processor bevatten.
Serienummers: tot op heden onbekend
2G GSM met banden/frequenties: 2/3/8 = 1900/1800/900
3G WCDMA (inclusief TD-SCDMA) met banden/frequenties: 1/2/5/8 = 2100/1900/850/900
4G LTE-FDD (inclusief LTE-TDD) met banden/frequenties: 1/3/7 = 2100/1800/2600
Full Netcom ondersteunt drie Chinese providers: China Mobile, China Unicom en China Telecom
Deze telefoon zal altijd een Qualcomm processor bevatten.
2G GSM (inclusief CDMA) met banden/frequenties: 2/3/8 =
3G WCDMA (inclusief TD-SCDMA en CDMA2000) met banden/frequenties: 1/2/5/8 =
Beide varianten zijn geschikt voor Europese GSM netwerken. 4G zal niet voor alle netwerken geschikt zijn. Het feit dat 3G op 850 en 900MHz zit, wil niet zeggen dat dezelfde range gebruikt kan worden voor 4G. Het netwerk moet geschikt gemaakt zijn in de hardware. Softwarematig unlocken van een frequentie is niet mogelijk.
Links:
Chinese Redmi Note 3 pagina (openen met Chrome voor een vertaling)
Voorgaande Redmi Note Topics:
[Xiaomi Hongmi (Redmi)] Ervaringen & Discussie
[Xiaomi Redmi Note 2] Ervaringen en Discussie
Chinaphone topic:
Het topic voor (onbekende) Chinese smartphones - Deel 3
[Ervaringen] Online shoppen in China - Deel 2a (ook geschikt voor kortingscodes)
\[(Onbekende) Chinese smartphones] - Levertijden en Prijzen.
Handige tooltjes & meer
Google Installer (PlayStore installeren
Redmi Note 3 Bootloader Unlocken
Rooten:
Als tip willen ik graag het volgende meegeven: Als je een Xiaomi tablet/telefoon besteld, probeer te voorkomen dat je er een andere rom op (moet)zet(ten). Je kunt namelijk problemen krijgen als je je toestel wilt rooten/flashen of voorzien van een nieuwe ROM. Vaak wordt er een ROM op gezet waar een hoop bugs of verouderde data in staat. Een bekende ROM die voor problemen zorgt is versie:
Root tips
Als je de Multilanguage rom van Xiaomi.eu installeert, dan is root toegang standaard mogelijk.
Het enige wat je daarvoor hoeft doen is root inschakelen bij de: Security app ->Permissions -> Root Access
Andere ROM installeren:
FAQ:
Waarom is het beter om voor de Multi Language (ML) rom van Xiaomi.eu te kiezen in plaats van de originele Chinese of Global Miui ROM?
Nadelen:
• Als er een bug in het systeem zit, dan wordt je mogelijk doorverwezen naar de originele source: namelijk en.miui.com. Hierdoor kan het langer duren voordat een bug wordt opgelost.
• De rom komt direct van de Engelse Miui site: en.miui.com. Vanuit die rom worden de onderstaande voordelen toegevoegd. Via een over-the-air (OTA) update, krijg je de update 1 tot enkele dagen later.
Voordelen:
• Bugs die zijn veroorzaakt door de taalpakketten, worden vaak binnen 1 week opgelost.
Nederlandse taal wordt wekelijks bijgewerkt (mits er fouten worden doorgegeven door NL gebruikers).
Link om taalfouten te rapporteren: http://xiaomi.eu/community/forums/dutch-translation.14/
• Je behoudt wekelijks updates (mits je gebruik maakt van de Weekly/Developer rom).
• Locatie van de GPS wordt aangepast van China naar een Europees land. Hierdoor verwacht je telefoon niet dat hij in China zit, maar ergens in Europa. Onder andere weer-gebaseerde apps werken hierdoor velen malen beter. Een voorbeeld hiervan is Buienalarm, dat werkt doorgaans niet/nauwelijks op een Chinese telefoon. Een lokale app zoals OV9292 werkt mogelijk ook niet goed als de locatie op China staat i.p.v. een Europees land.
• Zo goed als alle Chinese apps zijn verwijderd.
• Google Play is standaard geïnstalleerd.
• Standaard root toegang, die je zelf in kunt schakelen.
• De garantie zal je niet verliezen als je een ML rom op je Xiaomi apparaat zet. Wees echter wel heel erg voorzichtig en secuur met het vervangen van je rom.
De benodigde instructies om je ROM aan te passen, zijn nog niet geheel duidelijk omschreven. Er zijn teveel tegenstrijdigheden om de Xiaomi.eu rom op je originele telefoon te plaatsen. Zodra dit duidelijk een eenvoudig uit te voeren is, zal ik dit aan de topicstart toevoegen.
Is de telefoon geschikt voor ons netwerk?
• De telefoon is geschikt voor alle 3G netwerken in de Benelux
3G Netwerk: WCDMA 850/900/1900/2100 MHz
• Zoek contact met je provider om te achterhalen of 4G wordt ondersteund via deze netwerken:
4G Netwerk: FDD-LTE 1800/2100/2600 MHz
De topicstart willen we graag zo interessant mogelijk houden en extra input wordt zeer gewaardeerd. We hopen dat jullie ons kunnen helpen om interessante wetenswaardigheden over deze telefoon toe te laten voegen. Als er tips zijn om dit topic aantrekkelijker te maken, dan horen we dat ook graag. Je kunt ons daarvoor het beste een Persoonlijk Bericht sturen
[Voor 174% gewijzigd door Kiswum op 16-03-2016 17:16. Reden: Installatie voor een andere rom weggehaald, deze klopt helaas niet meer]
Dit topic is alleen bedoeld voor het bespreken van Ervaringen, andere onderwerpen horen in:
- Bestellen, levertijd en prijzen: \[(Onbekende) Chinese smartphones] - Levertijden en Prijzen.
- Rooten & Custom ROM's: Het grote MIUI custom-ROM-topic
- Unlocken van de Bootloader: [Centrale topic] Xiaomi Bootloader unlocken
Nintendo Switch (OLED model) Apple iPhone SE (2022) LG G1 Google Pixel 6 Call of Duty: Vanguard Samsung Galaxy S22 Garmin fēnix 7 Nintendo Switch Lite
Tweakers vormt samen met Hardware Info, AutoTrack, Gaspedaal.nl, Nationale Vacaturebank, Intermediair en Independer DPG Online Services B.V.
Alle rechten voorbehouden © 1998 - 2022 Hosting door True
Tweakers maakt gebruik van cookies
Tweakers plaatst functionele en analytische cookies voor het functioneren van de website en het verbeteren van de website-ervaring. Deze cookies zijn noodzakelijk. Om op Tweakers relevantere advertenties te tonen en om ingesloten content van derden te tonen (bijvoorbeeld video's), vragen we je toestemming. Via ingesloten content kunnen derde partijen diensten leveren en verbeteren, bezoekersstatistieken bijhouden, gepersonaliseerde content tonen, gerichte advertenties tonen en gebruikersprofielen opbouwen. Hiervoor worden apparaatgegevens, IP-adres, geolocatie en surfgedrag vastgelegd.
Meer informatie vind je in ons cookiebeleid.
Sluiten
Toestemming beheren
Hieronder kun je per doeleinde of partij toestemming geven of intrekken. Meer informatie vind je in ons cookiebeleid.
Functioneel en analytisch
Deze cookies zijn noodzakelijk voor het functioneren van de website en het verbeteren van de website-ervaring. Klik op het informatie-icoon voor meer informatie. Meer details
janee
    Relevantere advertenties
    Dit beperkt het aantal keer dat dezelfde advertentie getoond wordt (frequency capping) en maakt het mogelijk om binnen Tweakers contextuele advertenties te tonen op basis van pagina's die je hebt bezocht. Meer details
    Tweakers genereert een willekeurige unieke code als identifier. Deze data wordt niet gedeeld met adverteerders of andere derde partijen en je kunt niet buiten Tweakers gevolgd worden. Indien je bent ingelogd, wordt deze identifier gekoppeld aan je account. Indien je niet bent ingelogd, wordt deze identifier gekoppeld aan je sessie die maximaal 4 maanden actief blijft. Je kunt deze toestemming te allen tijde intrekken.
    Ingesloten content van derden
    Deze cookies kunnen door derde partijen geplaatst worden via ingesloten content. Klik op het informatie-icoon voor meer informatie over de verwerkingsdoeleinden. Meer details
    janee
