Sabnzbdplus start niet met boot? Ubuntu 14.10
  • relativity
  • Laatst online: 15-09 18:51
Hallo allemaal,
DIt probleem heb ik al eens eerder gehad, maar kon toentertijd geen bevredigend antwoord vinden.
Er staat niks in /var/log/boot.log:
$ cat /var/log/boot.log
 * Setting sensors limits                                                      [ OK ]
 * Setting up X socket directories...                                          [ OK ]
 * Starting early crypto disks...                                              [ OK ]
 * Restoring resolver state...                                                 [ OK ]
Loading tp-smapi kernel module...done.
Setting battery charge thresholds...done.
Applying power save settings...done.
 * Starting uuid generator uuidd                                               [ OK ]
Service is gewoon aanwezig:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
$ ls /etc/rc*.d
/etc/rc0.d:
K01sickbeard     K02openvpn              K04sendsigs
K02alsa-utils    K02postfix              K05rsyslog
K02apache2       K02pulseaudio           K06hwclock.sh
K02autosub       K02resolvconf           K06umountnfs.sh
K02bluetooth     K02sabnzbdplus          K07networking
K02cgmanager     K02speech-dispatcher    K08umountfs
K02cgproxy       K02thermald             K09cryptdisks
K02cups-browsed  K02tlp                  K10cryptdisks-early
K02fail2ban      K02unattended-upgrades  K11umountroot
K02hddtemp       K02urandom              K12mdadm-waitidle
K02irqbalance    K02uuidd                K13halt
K02lightdm       K03avahi-daemon         README
K02mdadm         K03mysql
/etc/rc1.d:
K01sickbeard     K02fail2ban    K02sabnzbdplus        K05rsyslog
K02alsa-utils    K02hddtemp     K02saned              README
K02apache2       K02irqbalance  K02speech-dispatcher  S01dns-clean
K02autosub       K02kerneloops  K02thermald           S01killprocs
K02bluetooth     K02lightdm     K02tlp                S01pppd-dns
K02cgmanager     K02mdadm       K02ufw                S02single
K02cgproxy       K02openvpn     K02uuidd
K02cups          K02postfix     K03avahi-daemon
K02cups-browsed  K02pulseaudio  K03mysql
/etc/rc2.d:
README        S03anacron     S03mysql              S06cups
S01apport     S03autosub     S03rsync              S06cups-browsed
S01cgmanager  S03cgproxy     S03speech-dispatcher  S06pulseaudio
S01dns-clean  S03cron        S03ssh                S06sabnzbdplus
S01pppd-dns   S03dbus        S03thermald           S06saned
S01rsyslog    S03fail2ban    S04avahi-daemon       S07grub-common
S01tlp        S03hddtemp     S04bluetooth          S07ondemand
S01uuidd      S03irqbalance  S04lightdm            S07rc.local
S02apache2    S03kerneloops  S04postfix            S07sickbeard
S03acpid      S03mdadm       S05openvpn
/etc/rc3.d:
/etc/rc4.d:
/etc/rc5.d:
S01dns-clean  S03cron        S03ssh                [b]S06sabnzbdplus[/b]
/etc/rc6.d:
K02irqbalance    K02uuidd                K13reboot
K02mdadm         K03mysql
/etc/rcS.d:
README             S03udev                    S08lvm2
S01console-setup   S04brltty                  S08urandom
S02alsa-utils      S04mountdevsubfs.sh        S09cryptdisks
S02apparmor        S04procps                  S10checkfs.sh
S02hostname.sh     S04udev-finish             S11mountall.sh
S02lm-sensors      S05hwclock.sh              S11networking
S02mountkernfs.sh  S06checkroot.sh            S12mountall-bootclean.sh
S02resolvconf      S07cryptdisks-early        S12mountnfs.sh
S02ufw             S08checkroot-bootclean.sh  S13mountnfs-bootclean.sh
S02x11-common      S08kmod                    S14bootmisc.sh
Handmatig starten is gewoon mogelijk:
$ sudo service sabnzbdplus start
 * Starting SABnzbd+ binary newsgrabber                                  [ OK ]
Heb al een paar keer gecontroleerd of er fouten in het init script staan, de service al een paar keer opnieuw geinstalleerd, maar ook een paar keer helemaal opnieuw geinstalleerd - niks werkt.
Iemand een idee?
  • vanaalten
  • Laatst online: 16-09 12:48
Ik ken Ubuntu niet zo, maar ik zou toch verwachten dat er wel *iets* in een logfile over hoort te staan.
Kan je eens kijken met
grep -l sabnzbd /var/log/*
... of er in een log file iets met sabnzbd genoemd wordt - en dan in die file eens verder kijken? Ik zou iets verwachten als daemon.log of syslog.
Ik draai hier Debian, die sterk op Ubuntu lijkt, hier zie ik in "boot.0" wel degelijk sabnzbd aangeroepen worden (mijn log ik ook een stuk langer dan wat jij laat zien - hoe heb je gefiltert?)
  • relativity
vanaalten schreef op zaterdag 27 september 2014 @ 09:07:
Daarom snap ik het dus ook niet :(
Net ook de autosub service geinstalleerd, maar precies hetzelfde probleem :/
$ grep -l sabnzbd /var/log/*
grep: /var/log/apache2: Is a directory
grep: /var/log/apt: Is a directory
/var/log/auth.log
/var/log/auth.log.1
grep: /var/log/btmp: Permission denied
grep: /var/log/ConsoleKit: Is a directory
grep: /var/log/cups: Is a directory
grep: /var/log/dbconfig-common: Is a directory
grep: /var/log/dist-upgrade: Is a directory
/var/log/dpkg.log
grep: /var/log/fsck: Is a directory
grep: /var/log/hp: Is a directory
grep: /var/log/installer: Is a directory
grep: /var/log/lightdm: Is a directory
grep: /var/log/mysql: Is a directory
grep: /var/log/speech-dispatcher: Permission denied
grep: /var/log/unattended-upgrades: Is a directory
grep: /var/log/upstart: Is a directory
Weinig te vinden :/
Ben misschien ook van plan om debian te dual booten. Die gebruikt nu ook XFCE of niet? _/-\o_
[ Voor 3% gewijzigd door relativity op 27-09-2014 15:58 ]
  • Caelorum
  • Laatst online: 07:05
Ik draai hier linux mint en ik kan ook niets vinden in de logs (commando hierboven is ook niet helemaal juist lijkt het?), maar sabnzbdplus werkt gewoon goed hier. Start netjes op met het systeem, maar een melding daarvan in een log daarvan ben ik nog niet tegengekomen. Heb em gewoon uit de repo van linux mint geinstalleerd (staat ook in die van ubuntu 14.04).
Heb je in /etc/default/sabnzbdplus wel alles goed staan? (niet toevallig ooit een aparte user aangemaakt en die nu verwijdert?) Die wordt zowel door het upstart als het init.d script gebruikt.
  • Hero of Time
  • Laatst online: 00:32
Hero of Time
Moderator LNX
There is only one Legend
Enige wat ik kan bedenken waarom 't niet werkt, is omdat 't niet bij systemd is aangemeld als service. Heb je commando's als 'systemctl' beschikbaar? Voer dan de volgende twee eens uit en geef 't antwoord daarop, na een schone boot (dus zonder dat je zelf sabnzb hebt aangeslingert):
systemctl is-active sabnzb
systemctl is-enabled sabnzb
Verders werkt Debian niet standaard met Xfce, maar heeft het wel altijd in z'n repo gehad. Via Advanced Installation opties kan je de default GUI aanpassen van Gnome naar KDE of Xfce als je wilt. Welke smaak van Debian was je van plan te gebruiken, Wheezy (current stable), Jessie (op 't moment in Testing, welke nu in freeze staat), bij Testing blijven of Sid (Unstable)? Als je namelijk voor Testing/Jessie of Sid gaat, krijg je te maken met Systemd en dat werkt net even wat anders mbt services die bij boot starten. Heel /etc/init.d wordt daar niet gebruikt en bestaat alleen voor compatibiliteit als je toch nog terug wilt gaan naar een init-based service beheer.
Overigens hoort dit topic beter in NOS, want er is niets mis met je pakket, alleen de systeemconfiguratie ervoor en dat wordt niet in CSA besproken. Vandaar dat ik 'm verplaats.
Commandline FTW
