En
aangekondigd!
PENTAX ANNOUNCES smc PENTAX DA 18-250mm F3.5-6.3ED AL [IF]
October 1, 2007
HIGH-PERFORMANCE ZOOM LENS
GOLDEN, CO. (October 1, 2007)…PENTAX Imaging Company is pleased to announce the smc PENTAX DA 18-250mm F3.5-6.3ED AL [IF] interchangeable zoom lens designed for exclusive use with PENTAX digital SLR cameras. With an approximate 14X zoom ratio covering from wide-angle to super-telephoto ranges, this versatile lens handles a great variety of applications from wide-angle landscapes to close-up sporting events and wildlife photography.
The lens will ship in October for US $499.95.
Images are available for download here:
http://www.pentaxtech.com/Press/pressfiles.html
PENTAX Imaging Company is an innovative leader in the production of digital SLR and compact cameras, lenses, flash units, binoculars, scopes, eyepieces and mobile printers and scanners. For more than 80 years, PENTAX technology has developed durable, reliable products that meet the needs of consumers and businesses. With headquarters in Golden, Colorado, PENTAX Imaging Company is a division of PENTAX of America, Inc.
Media Contact:
Michelle Martin 303.728.0224
michelle.martin@pentax.com
Consumer Product Information:
1-800-877-0155
pentaxinfo@pentax.com
www.pentaxslr.com
SMC PENTAX DA 18-250mm F3.5-6.3ED AL [IF] ZOOM LENS
FACT SHEET
High zoom ratio
Mounted on a PENTAX digital SLR camera body, this zoom lens offers approximate 14X zoom ratio that covers the range from 27.5mm wide angle to 383mm super-telephoto in the 35mm format. Without the need for lens changes, it can be used for a wide variety of applications — ranging from such standard applications as landscape photography, snapshots and portrait at frequently used focal lengths, to specialized applications like sports and wildlife photography at the super-telephoto range.
Superb image description assured by extra-low dispersion (ED) and aspherical optical (AL) elements
Incorporating two extra-low dispersion (ED) elements and two aspherical (AL) elements, this lens effectively compensates for the adverse effects of various aberrations, assuring outstanding image description.
Digital SLR exclusive design
This lens is exclusively designed for use with PENTAX digital SLR cameras, with its image circle perfectly proportioned to their image sensor size (23.5mm x 15.7mm). Since the coating, curvature and position of all optical elements are optimized for the characteristics of digital images, the lens effectively minimizes annoying flare and ghost images in the resulting images.
Minimum focusing distance
An extra-short minimum focusing distance of 0.45 meters over the entire zoom range
Inner-focus (IF) mechanism to avoid lens extension during focusing.
Main Specifications
* Lens mount: PENTAX KAF mount
* Lens construction:········· 16 elements in 13 groups
* Angle of view: 76° ~6.5° (when mounted on a PENTAX digital SLR camera body)
* Number of diaphragm blades: 7
* Minimum aperture: F22 ~ F45
* Minimum focusing distance: 0.45m (1.48ft)
* Filter size: 62mm
* Maximum magnification: 0.28X
* Dimensions & weight:
75mm (maximum diameter) x 85.5mm (length)
(3.0 inch x 3.4 inch);
16.0 oz (455g) (without lens hood)
(klikken voor een grotere afbeelding)
Ik ben wel benieuwd wanneer die in Nederland te koop zal zijn en voor welke prijs. Ik hoop zo rond de 400 euro. Dan kan ik die mooi meenemen op reis naar Chili vanaf eind januari.
