installeerprobleem
  • 33 views sinds 30-01-2008
bij meerdere programma's en spelletjes (o.a originele lego - cd)krijg ik steeds de melding:
16-bits windows-subsysteem
C:\windows\system32\autoexec.nt
Het systeembestand is niet geschikt voor MS-dos en MSwindows toepassingen
Kies sluiten om de toepassing af te sluiten
Weet jij wat dit is / hoe dit kan
het gebeurd ook bij een origineel lego spel, dat voorheen wel werkte in XP.
  • Palomar
Wat staat er dan in dat bestand? (openen met notepad).
Bij mij staat dit erin:
@echo off
REM AUTOEXEC.BAT is not used to initialize the MS-DOS environment.
REM AUTOEXEC.NT is used to initialize the MS-DOS environment unless a
REM different startup file is specified in an application's PIF.
REM Install CD ROM extensions
lh %SystemRoot%\system32\mscdexnt.exe
REM Install network redirector (load before dosx.exe)
lh %SystemRoot%\system32\redir
REM Install DPMI support
lh %SystemRoot%\system32\dosx
REM The following line enables Sound Blaster 2.0 support on NTVDM.
REM The command for setting the BLASTER environment is as follows:
REM SET BLASTER=A220 I5 D1 P330
REM where:
REM A specifies the sound blaster's base I/O port
REM I specifies the interrupt request line
REM D specifies the 8-bit DMA channel
REM P specifies the MPU-401 base I/O port
REM T specifies the type of sound blaster card
REM 1 - Sound Blaster 1.5
REM 2 - Sound Blaster Pro I
REM 3 - Sound Blaster 2.0
REM 4 - Sound Blaster Pro II
REM 6 - SOund Blaster 16/AWE 32/32/64
REM
REM The default value is A220 I5 D1 T3 and P330. If any of the switches is
REM left unspecified, the default value will be used. (NOTE, since all the
REM ports are virtualized, the information provided here does not have to
REM match the real hardware setting.) NTVDM supports Sound Blaster 2.0 only.
REM The T switch must be set to 3, if specified.
SET BLASTER=A220 I5 D1 P330 T3
REM To disable the sound blaster 2.0 support on NTVDM, specify an invalid
REM SB base I/O port address. For example:
REM SET BLASTER=A0
Maak evt. even een backupje van het huidige bestand en maak een nieuwe met bovenstaande inhoud.
[ Voor 4% gewijzigd door Palomar op 16-06-2005 21:59 ]
  • BalusC
BalusC
Carpe diem
Het is niet de bedoeling om een probleem op meerdere plaatsen te gaan crossposten. Aangezien je hier relatief nieuw bent, verzoek ik je vriendelijk om terug te klikken naar de [faq]registratievoorwaarden[/] en deze alsnog rustig en aandachtig te doornemen en dan met name het forumgedrag gedeelte. Zodoende kun je jezelf een beter beeld verschaffen van hetgeen wij hier op GoT van de gebruikers verwachten ;)
Hier verder dus: opstart/installeerproblemen
