Hi LIAM,
after my experience with Chieftec I can only recommend you a Server tower from them. You should take a look at the DRAGON series at this link:
http://www.chieftec.com/products/Workcolor/ColorDA.htm
One of those Full Tower File Server Cases would certainly do the job in terms of space and upgradeability. Here are the specifications:
Dimension: 470x 205x 670mm(DxWxH).
Drive: 6 x 5.25"+2 x 3.5"FDD+ 6 x 3.5"HDD.
Fits different size M/B, including 12"Wx 13"L XEON motherboard.
Optional 4 x (80 x 80 x 25)mm cooling fans.
Optional side panel cooling fan.
Install PSII, PSII redundant or standard redundant PSU.
Net/Gross Weight=15/16Kgs(w/o PSU).
You can also have a look inside the case at this link:
http://www.chieftec.com/products/workstation/Fulltower.htm
Just check it out. Chieftec products are of very decent quality and contrarily to other top brands (Supermicro, InWin, Antec to name a few) are way cheaper in price. But believe me they are as good if you compare by category. The slide doors (on the sides) and the front door of the tower open and close perfectly. There is no single place where you could cut yourself and if you take the right model (as above) you can fit LOTS of stuff into it.
And the price is right I think. SAILLAND AUTOMATISIERING has the DA-01B-D for 131 ¤ incl 340W PSU. More shops are offering this tower:
http://www.tweakers.net/pricewatch/23943
You can also get it without PSU I believe and then it should cost around 100 ¤ or thereabout since that is what the included Chieftec PSU is worth (30 ¤ or so). Of course you have to ask about that - I live in Germany and shops offer it with and without PSU since many people like to put it their own or favorite PSU.
Anyway, Chieftec has got much more on offer so I suggest you check their website and I am sure you can find a model you like there. But the others will not offer you more than the one I mentioned above. Just see for yourself. Cheers.
Regards,
