[Ghostrider]
Asus G74SX I-7 2630QM 8Gig ram GTX 560M 3GB
Workstation I7-920@3,8ghz 6Gig ram GeForceGTX275 Dell U2711 80GB SSD + Dell Perc 5/i Raid 1
Je moet wel een map PS3 aanmaken met daarin een map UPDATE. Zet daarin de nieuwe firmware. Dan werkt het wel!quote:Gumball schreef op vrijdag 17 oktober 2008 @ 10:13:
Ik heb gister de 2.5 firmware gedownload en op een USB stick geplaatst. Vervolgens stick in PS3 gestopt, echter zegt de PS3 dat er geen firmware gevonden wordt. Heb de firmware al opnieuw gedownload, maar dat hielp niets. heb vorige versie van de firmware wel op deze manier geüpdate
Reg. datum: 21 februari 2006
An update to the PS3 system software was released on October 15, 2008. If you update your PS3 system, the system software version will be 2.50 and the following features will be updated. In order to download PS3 system software version 2.50, you will need a minimum 140Mb of free space on either the PS3 Hard Disk Drive (System Update) or on removable storage media (PC Update).
Main features in system software update version 2.50
PlayStation®Network
The account creation screens under [Sign Up for PlayStation®Network] and the menus under [Account Management] have been redesigned.
Other new or revised features in version 2.50
Users
You now have an option to set the PS3 system to turn off automatically after a background download or installation of content has been completed. This option is available when you are turning off the system under [Users] > [Turn Off System] while content is being downloaded or installed.
Settings
[BD/DVD Settings] has been renamed as [Video Settings].
Under [Video Settings], the [Cinema Conversion] and [Upscale] options have been renamed as [BD/DVD Cinema Conversion] and [BD/DVD Upscaler], respectively.
[Sequential Playback] and [50 Hz Video Output] have been added as options under [Video Settings].
[DivX® VOD Registration Code] has been added under [System Settings]. You must use this registration code to authenticate and register the PS3 system to be able to play video files that are compatible with the DivX® VOD (Video On Demand) service on your system. For details, visit divx.com/vod/
[Power Save Settings] has been added as an option under Settings. To save power, the PS3 system and Wireless controllers can be set to turn off automatically after a certain period of inactivity.
Under [Accessory Settings] > [Audio Device Settings], the method for reconnecting Bluetooth® devices has been changed.
Under [Accessory Settings] > [Keyboard Type], you can now choose the following keyboard types: [German Keyboard (Switzerland)], [French Keyboard (Canada)] and [French Keyboard (Switzerland)].
In the keyboard layout for [German Keyboard], the "Y" and "Z" keys have been switched and the "Q" and "A" keys have been switched.
Under [Printer Settings] > [Printer Selection], you can now select printers that support network connectivity. You can also select HP printers using the [HP] option.
Music
You can now select one of nine volume output levels using the [Volume Control] setting on the control panel (or the mini-size control panel).
[Pause] has been added as an icon on the mini-size control panel.
Video
You can now select one of nine volume output levels using the [Volume Control] setting on the control panel.
[Scene Search] has been added as an option on the control panel.
You can now use the [Mosquito Noise Reduction] setting for video content that is saved on the hard disk or storage media. Use this setting to reduce mosquito noise that appears on the edges of visual images.
During BD (BDAV) and DVD playback, a technique known as “chroma upsampling” is now automatically selected based on the movement of objects within the video content and then applied to enhance images in the content.
Game
[Sync with Server] has been added as an option under [Trophy Collection].
By pressing the PS button while playing PLAYSTATION 3 format software, you can now view information from the [Settings and Connection Status List] option under [Network Settings].*
* This feature is not available for use with some PLAYSTATION 3 format software.
Network
Support for Adobe® Flash® Player 9 has been added to [Internet Browser].*
* “Adobe” and “Flash” are either registered trademarks or trademarks of Adobe Systems Incorporated in the United States and/or other countries.
PlayStation®Network
The way to disable the automatic sign-in option and the way to sign out from PlayStation®Network have been changed.
In PlayStation®Store, the design of the [View Downloads] and [View Cart] buttons has been changed, and a [Redeem Codes] button has been added.
Note:
This system software update includes all features contained in previous versions.
The new system software will preserve any settings previously made to the PLAYSTATION 3.
Depending on the software title, you may not be able to play without first updating the PS3 system software.
Do not perform updates using any data other than the official update data provided by Sony Computer Entertainment over a network or on disc media, and do not perform updates by methods other than those described in the product documentation or in this site. If an update is performed using data from another source, by another method, or with a PS3 system that has been altered or modified in any way, the PS3 system may not operate properly and may not be able to install the official update data. Any of these actions may void the PS3 system warranty and affect your ability to obtain warranty services and repair services from Sony Computer Entertainment.
PSN id: iVonTurK
Vreemd. Het heeft echt gewerkt door de PS3UPDATE.PUP (of hoe die file maar heet) gewoon in de root van de stick te zetten. Echter, ik zal jouw manier straks maar eens proberen! Bedankt voor je reactie.quote:SpeedingWilly schreef op vrijdag 17 oktober 2008 @ 10:44:
Ik moet ze anders nog steeds handmatig aanklikken om te installeren??quote:Ghostrider schreef op vrijdag 17 oktober 2008 @ 10:31:
De functie dat downloads automatisch geinstaleerd werden zat al in een oudere update.
PSN ID: drT3000 ------------- HTC Android HD2
Reg. datum: 03 december 2006
oh? Maar dat was nog niet zo toen ik vorige week Bioshock heb gedownload. Die moest ik gewoon na het downloaden installeren.quote:Ghostrider schreef op vrijdag 17 oktober 2008 @ 10:31:
Playstation 3 - PSN ID: Sw0pDiller | XBOX360 Premium - Gamertag: ZakkeWasser | DELL New Studio 17 laptop
Als je een download niet naar de achtergrond verplaatst maar vanaf het begin in de voorgrond laat lopen wordt hij automatisch geinstalleerd.quote:swopdark schreef op vrijdag 17 oktober 2008 @ 12:45:
PSN: Shiver23 //
Amen!!!quote:alvi schreef op donderdag 16 oktober 2008 @ 18:27:
Als ze gewoon nog een vette ssx konden maken, dan was het helemaal in orde
Zit er echt van te balen dat er nog geen nieuwe is. Ik snap het niet spel was toch populair en goed verkocht?
Ik weet dat de tak die het ontwikkelde gestopt is door EA maar dr moet toch iemand anders zijn die er brood in ziet
Reg. datum: 05 juli 2001
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." Dave Barry
Heb er wel van gehoord, maar lijkt het qua gameexperience en gamemodes op SSX
Skire wijzigde dit bericht 17-10-2008 16:13 (37%)
Oow ik kan echt niet meer wachten op het spel...ondanks dat het screenshots zijn, zijn de personages toch...'Mafia''-achtig
http://www.gamingonly.nl/...ots/1224189948/ori_01.jpg
http://www.gamingonly.nl/...ots/1224189948/ori_02.jpg
(edit) Ik lees die gamer.nl thread nog eens en volgens mij hebben ze wel erg snel conclusies getrokken van een thread op een forumpje.... want er is verder dan die thread niets aan de hand volgens mij...
EfBe wijzigde dit bericht 17-10-2008 16:41 (25%)
Lead developer of LLBLGen Pro, the productive O/R mapper for .NET
My .NET Blog | Twitter
Reg. datum: 01 november 2006
http://www.gamesindustry....release-delayed-in-europequote:LittleBigPlanet release delayed in Europe
The release of Sony's highly anticipated PlayStation 3 title LittleBigPlanet has been delayed in Europe.
The game was due for release next week, October 24, but now some retailers are estimating the game may be delayed by three weeks until November 14.
However, GamesIndustry.biz understands that the title may not suffer such a long delay to retail, and a new date is expected to be announced by Sony shortly.
LittleBigPlanet has reviewed incredibly well in the specialist press and anticipation is high from consumers who have already had access to the beta of the game.
Sony has said that the game is a system seller for the PlayStation 3, and the title is considered one of the most important releases for the home console this Christmas
simplicidad wijzigde dit bericht 17-10-2008 16:46 (92%)
TODAY IS THE TOMORROW THEY PROMISED YOU YESTERDAY.
Reg. datum: 10 december 2007
Volgens de laatste geruchten is dit gerucht ook niet waar, dus blijkbaar valt t allemaal wel mee.quote:dialMforMike schreef op vrijdag 17 oktober 2008 @ 17:34:
Dat zou niet zo mooi zijn. Na het behalen van mijn rijbewijs eind vorige week heb ik besloten mijzelf een PS3 cadeau to doen en het leek mij het mooist om dan de LBP pack te kopen aangezien die titel mij wel aanspreekt. Als het nu nog langer gaat duren dan koop ik een X360! Nou nee zo erg is het ook weer niet, maar ik wilde toch graag snel gamen. Ik haat wachten %\
Naar twee weken toch maar gekocht voor 10 euro. Ik vind de nieuwe maps erg leuk.
Zie ik hem nu wel voor 5 euro in de shop staan
http://threespeech.com/bl...scees-official-statement/quote:SCEE has supplied us with the official statement on the situation regarding LittleBigPlanet…
During the review process prior to the release of LittleBigPlanet, it has been brought to our attention that one of the background music tracks licensed from a record label for use in the game contains two expressions that can be found in the Qur’an. We have taken immediate action to rectify this and we sincerely apologise for any offence that this may have caused.
We will confirm the new launch date shortly.
k*t, dus ook mijn exemplaar uit Canada.
Dat is inderdaad fijn kl*te dat het wereldwijd is.. Ben benieuwd hoe lang het gaat duren voordat de game dan gereleased wordt..quote:M a r c o schreef op vrijdag 17 oktober 2008 @ 18:09:
Niet europees dus, maar wereldwijd.
Toch wel erg dat ze er pas 1 week voor de release date achter komen...
l00pz wijzigde dit bericht 17-10-2008 18:17 (10%)
Reg. datum: 07 december 2004
Alle packs die nu al klaar staan en geproduceerd zijn (dus dozen met boxart) terug opendoen en de game eruit halen en vervangen? (althans ik mag hopen dat er nu al packs gemaakt zijn)
Ook alle andere geperste schijfjes vernietigen en nieuwe maken?
Voor wat eigenlijk? Twee koran zinnetjes in een stukje gebruikte muziek. Djeezes, waar zijn we op deze planeet mee bezig. Je moet elk stukje auteursrechterlijk materiaal die je ergens in een game/film gebruikt tegenwoordig dood analyseren om te bekijken of er niet iets in zit wat drie man kan beledigen.
Hadden ze het niet gezegd, ik had het waarschijnlijk nooit gehoord (daarbij, als het in een oorspronkelijke taal was opgenomen had ik het nog eens niet begrepen ook)
Ik baal hiervan, omdat m'n tv morgen geleverd wordt, en ik dus op het eind van de maand van plan was om die pack te halen. Ik koop lbp liever met de pack, omdat lbp in een pack gewoon veel goedkoper is dan ps3 + lbp en omdat ik lbp toch absoluut wil hebben. Eens zien of ik het geduld kan opbrengen of toch al een ps3 haal, hoop van niet... (want m'n tv was toch wel al erg duur
Daarom post ik het ook hierquote:DarthDavy schreef op vrijdag 17 oktober 2008 @ 10:04:
Wat een geluk voor jou dat je dit in het PS3 topic post. Als je dit in het Xbox360 topic had gezet, dan waren ze je nu aan het lynchen.![]()
Als PS3-owner ben ik het met veel punten van je eens, maar dit is ongeveer wel de meest subjectieve vergelijking tussen de PS3 en de Xbox360 die ik dit jaar gelezen heb.
Ik word eerlijk gezegd een beetje moe van het adagium dat elke tweaker zo neutraal moet zijn als Zwitersland. Zolang je duidelijk aangeeft dat het een eigen mening is en iedereen maar respecteert in z'n keuze, is er toch geen probleem?
Alles moet hier overbeargumenteerd worden, zodat je bijna immuun wordt voor het gevoel die bij de games komt kijken.
Games is een hobby, een 'passie', nogal logisch dat zoiets subjectief is. Anders wordt het gewoon 'werk' imo. Ik heb ook een voorkeur voor Ferrari, Federer, vond Armstrong geweldig, <voeg willekeurige voorkeur in> Het ligt in de aard van de mens om daar subjectief en gevoelsmatig over na te denken.
En sony raakt bij mij de juiste snaren, de 'vibe' zit goed. Voornamelijk omwille van nostalgie (ps1, ps2), maar ook omdat ik me kan vinden in de keuzes die sony maakt voor console entertainment. Ook qua 'sfeer' liggen de sony games me meer. Ik kan 5 games opnoemen die qua genre gewoon niet op de xbox te krijgen zijn of ondervertegenwoordigd, terwijl ik bij de xbox maar één game kan vinden die ik misschien wel wil spelen, namelijk Gears of War 2.
Je geeft toch geen 400 euro uit in een gortdroge vergelijking van specs. Het gaat om gevoel en de games die bij het platform horen. Dan ben ik maar 'fan' van het ps platform, en laat het ms platform me redelijk syberisch koud. Kan ik ook niets aan doen. Zelfs al kostte een xbox 50 euro...
Ik geef echter zonder problemen toe dat de xbox ook z'n sterke punten heeft. it just doens't rock my boat
alvi wijzigde dit bericht 18-10-2008 02:00 (57%)
keep on dreamin'quote:swopdark schreef op donderdag 16 oktober 2008 @ 10:05:
iets anders:
Ik ga vanaaf Dead Space halen en ik zag gisteren en vergelijkingsvideo tussen de 360 en PS3 versie. Het lijkt er nu eindelijk van de komen: de PS3 uitvoeringen van multiplatformers worden gelijkwaardig of zelfs iets beter dan de 360 versies.
de multiplatforms zijn al een tijdje min of meer gelijkwaardig en dat zal ook zo blijven. De enige reden die ik kan bedenken waarom de ps3 betere graphics zou kunnen hebben is omdat ze meer opslag hebben voor textures. Maarja, dan zit je weer met het mindere geheugen. de cell is beter, maar die zorgt niet voor de plaatjes. De gpu is min of meer gelijkwaardig (net iets in het nadeel van de ps3). Dus als jij gelooft in het Sony-sprookje van betere graphics moet je dat vooral doen, maar net als met de littlebigplanet releasedatum kom je bedrogen uit.
Xbox live gamertag: Metsadah - PC: E4300, 2gb ddr, HD4850
Als atheist heb je het zwaar in dit land
Als er daadwerkelijk een muziekstukje is wat niet gebruikt kan worden, heb je toch gewoon een verplichte patch op launchdate?
Het zou wel heel treurig zijn als dit daadwerkelijk de reden is. Dit uitstel kost miljoenen dollars.
Nu, met zonder ondertitel
quote:So within 12 hours of hearing about this issue involving a lyric (in Somalian, I believe!), we prepared an automatic day 0 patch and had a new disk image ready; however a decision was made within Sony that the right thing to do for quality and support of people with no on-line was to replace existing disks.
De angst voor moslimextremisten zit er flink in. Er is in het middenoosten maar weinig voor nodig om aan het protesteren te slaan. Vaak wordt dit door lokale regeringen uitgebuit om het westen te chanteren. Sony wil niet het risico nemen dat die twee Arabische zinnetjes in een stukje achtergrondmuziek door een mullah (of regeringsleider) wordt gebruikt om weer tegen het boze westen te ageren door middel van boze brieven, krantenkoppen, protesten, boycots, fatwa's, doodsbedreigingen of zelfs aanslagen.quote:PWM schreef op vrijdag 17 oktober 2008 @ 18:34:
Ik geloof er niks van dat dit de reden is van het uitstel![]()
Xbox Gamer Tag ...Wii, Xbox, Xbox 360, PSP, PS2, PS3...
Reg. datum: 10 maart 2002
The single most important component of a camera is the twelve inches behind it. Ansel Adams
Reg. datum: 13 november 2005
Beetje kortzichtig, niet?quote:PWM schreef op vrijdag 17 oktober 2008 @ 18:34:
Vergeet niet dat meer als de helft van de PS3's nooit online komt, hoe wil je zo'n patch dan bij de gebruiker door de strot duwen.
[edit] typo's
Wel vraag ik me af welke 5 games die qua genres je dan op de 360 mist of ondervertegenwoordigd vindt. De oude xbox had inderdaad zeer weinig diversiteit aan genres, zeker als je dit vergelijkt met de PS2 want dat is in mijn ogen gewoon de meest complete console ooit. Maar de 360 heeft in mijn ogen toch wel redelijk wat genres nu? Misschien missen ze inderdaad een game als LBP, maar voor de rest lijken ze me vrij gelijk? Zeker met de releases die dit jaar nog uitkomen.quote:alvi schreef op vrijdag 17 oktober 2008 @ 18:23:
Goed verhaal!
uchiha tijntje wijzigde dit bericht 17-10-2008 19:57 (5%)
360Gamertag.....PSN ID
Reg. datum: 12 juli 2007
Wel alleen Europa, SCEE is Europa en die hebben alleen maar een aankondiging gedaan.quote:M a r c o schreef op vrijdag 17 oktober 2008 @ 18:09:
Hoe wil jij een patch forceren bij een game waarvan de disks al klaar zijn en bij mensen terecht komen die echt niet allemaal hun PS3 aan het internet hebben hangen?quote:PWM schreef op vrijdag 17 oktober 2008 @ 18:34:
Als er een game is waar de PS3 voor aan het inet moet hangen is het LBP wel volgens mijquote:1shot1kill schreef op vrijdag 17 oktober 2008 @ 20:06:
uchiha tijntje wijzigde dit bericht 17-10-2008 20:13 (10%)
Toch wel wereldwijd, update op threespeech:quote:1shot1kill schreef op vrijdag 17 oktober 2008 @ 20:06:
Bijzonder triest dat de angst er bij sommigen zo diep in zitquote:UPDATE
We’ve just been informed by SCEE that the delay to release is effective worldwide.
Edit: Bovendien als het een quote uit de Koran is dan zal dat toch geen moslim beledigen? In heel veel liedjes hoor je ook elementen uit de Bijbel, geen christen die je daar over hoort.
@ Efbe: Wat is een reliegroep?
JeepXJ89 wijzigde dit bericht 17-10-2008 21:01 (21%)
PS3 80gb met 320gb, PSN tag: Papegaaienflats
Reg. datum: 16 februari 2007
Dat is dus maar 5 dagen laterquote:We will begin shipping LittleBigPlanet to retail in North America the week of October 27th.
PSN ID: blu-fox
Als jij die patch klaar hebt liggen, is er echt niemand die er boos om gaat worden, ook niet de gevreesde moslims. Juist het feit dat het bedrijf er direct op springt zegt al genoeg.quote:1shot1kill schreef op vrijdag 17 oktober 2008 @ 20:06:
Dat niet iedereen die patch krijgt, maakt dan echt niet uit. Het gaat er om dat een bedrijf sorry zegt, en er wat aan doet, klaar.
Ik vind overigens niet dat je sorry moet zeggen, maar indirect doet Sony dat nu natuurlijk ook.
Los daarvan vraag ik me af of er 1 moslim boos om geworden zou zijn
Dat zal neem ik aan shiping vanuit de Blu-Ray bakker in China/Japan zijn.quote:hesr schreef op vrijdag 17 oktober 2008 @ 21:03:
Op het PlayStation blog:
PWM wijzigde dit bericht 17-10-2008 22:03 (19%)
Ik snap ook weinig van dat stuk van zijn verhaal. Zelfs de Japanse ontwikkelaars springen massaal over naar Microsoft en Nintendo(met het altijd 'loyale' Square-Enix als eerste natuurlijkquote:uchiha tijntje schreef op vrijdag 17 oktober 2008 @ 19:54:
Het Little Big Planet verhaal is overigens ook onzin zeg. Ik ben 'offended' bij de Koran maar die wordt niet uitgesteld of teruggeroepen uit de winkels. Als je een boekje wilt lezen en wilt geloven in fabeltjes moet je dat lekker zelf weten maar ga niet huilen als andere mensen daar geen zin in hebben. Geen recall en laat ze maar hard genoeg bidden als goden echt bestaan dan verdampen alle diskjes automatisch.
Left for greener pastures(NeoGAF/Wii-DS) :W
ymmv wijzigde dit bericht 17-10-2008 22:39 (8%)
Jij hebt de afgelopen 8 jaar in een grot geleeft? Je hoeft maar een verkeerde tekening te maken en je land word doelwit van terroristen, je hoeft maar sex te hebben op een strand in een streng moslim land en je kan zonder bewijs jaren de cel in en als je een Teddybeer Mohammed noemt mag je nog van geluk spreken als je alleen maar zo'n land word uitgezet en niet word afgemaakt door de woedende menigte buiten de gevangenis waar je tijdelijk in zit.quote:PWM schreef op vrijdag 17 oktober 2008 @ 21:47:
En dit zien ze als veel erger dan de bovengenoemde dingen.
Omdat ze vinden dat je de profeet niet mag afbeeldenquote:Jij hebt de afgelopen 8 jaar in een grot geleeft? Je hoeft maar een verkeerde tekening te maken en je land word doelwit van terroristen
Onzinverhaal. Ze waren gewaarschuwd, bleven doorgaan, nog een keer gewaarschuwd, bleven doorgaan, en daarna begon die vrouw de agent te beledigen. Als je zo graag opgepakt wilt worden... Los daarvan staat het in de wet van dat land, en dat weet je dondersgoed als je daar bent. Gewoon stom gedrag van 2 dronken britten.quote:je hoeft maar sex te hebben op een strand in een streng moslim land en je kan zonder bewijs jaren de cel in en
Wederom, de Profeet.quote:als je een Teddybeer Mohammed noemt mag je nog van geluk spreken als je alleen maar zo'n land word uitgezet en niet word afgemaakt door de woedende menigte buiten de gevangenis waar je tijdelijk in zit..
Ik zeg niet dat in Moslim landen het lontje af en toe kort is, maar deze actie lijkt me schromelijk overdreven. Daarbij word de tekst gebruikt, niet misbruikt. Ik ben benieuwd of er uberhaupt nog een reactie komt.
PWM wijzigde dit bericht 17-10-2008 23:05 (15%)
Killzone 2 geeft ook keys weg:
http://www.nu.nl/news/179...akeys_Killzone_2_weg.html
Reg. datum: 05 september 2001
Ik snap het ook niet. In Assassin's Creed wordt de koran en ook de bijbel aangehaald op een nogal sarcastische manier. Niemand die daar over viel of wel dan? Beetje overdreven.quote:EfBe schreef op vrijdag 17 oktober 2008 @ 18:28:
(LBP uitstel) Kennelijk om een rel te voorkomen of iets dergelijks, maar ik snap de heisa niet echt: het gaat om een miniem klein dingetje, waar een groepje relies over kunnen vallen, maar dat is toch uberhaupt altijd wel het geval? Zijn het niet reliegroepje X dan wel reliegroepje Y, en als de relies het best vinden is er wel een andere instantie die er weer wat over te klagen heeft, zoals de drugnamen in Fallout 3.
Als atheist heb je het zwaar in dit land. Anyway, dan maar ff wachten... tenzij een andere groepering iets weet te melden natuurlijk...
Je mist het hele punt, je mag van de Islam een tekst uit de Koran niet in een liedje gebruiken, dat is voor de radicale moslims hetzelfde als die dingen van de profeet.quote:PWM schreef op vrijdag 17 oktober 2008 @ 23:01:
5 is misschien te veel, maar ik ben een grote fan van platformers.quote:uchiha tijntje schreef op vrijdag 17 oktober 2008 @ 19:54:
Dus Little Big Planet en Ratchet and Clank zijn er al zeker twee. Kameo vond ik bvb niet veel aan.
Ik bedoelde dat ik eerder zo vijf games kon opnoemen die me op het lijf geschreven zijn en niet vind op de xbox, qua genre mis ik er idd eigenlijk maar één: platformers.
Andere games: wipeout, MGS, en GT5. De vijf games die ik opnoem zijn al genoeg redenen voor mij om voor het ps platform te kiezen.
De rest (tom clancy, tomb raider, mafia, mirrors edge, far cry 2, EA sports, prince of persia) zijn allemaal cross platform, dus die kan ik ook gemakkelijk meepikken (en ze verschillen slechts miniem van elkaar). Gratis multiplayer heeft ook m'n voorkeur.
MS heeft het (voor mij) deze generatie niet echt waargemaakt. Nogmaals, als de opvolger van de 360 een killer console wordt, komt die er bij mij misschien wel in, maar voor deze generatie pas ik (nogmaals).
Reg. datum: 08 juli 2003
PS3 120GB Slim PSN: Bierbeer
naja edit ik deze wel
Blijkbaar heeft een zeker Nsider (dit is niet zijn echte naam natuurlijk) tijdens het reviewen van LittleBigPlanet de zinnen uit de Koran gevonden. Hij stuurde vervolgens een mail naar Sony met de vraag om deze te verwijderen, tot zijn grote verbazing deed Sony dit ook. Deze Nsider bood vandaag dan ook zijn excuses aan.
Bron: http://ps3life.nl/nieuws/...l_biedt_zijn_excuses_aan/quote:I’m sorry for partially causing a one week delay of LittleBigPlanet. I’m sorry Sony has to go through all the trouble of pulling the game from stores and replacing them with patched versions. I definitely know what it feels like to have a game delayed.
The possibility that Sony would delay the game didn’t even cross my mind. I thought that they will do nothing about it for weeks then quietly release a patch much later.
I’m sorry. :(”
FireBladeX wijzigde dit bericht 18-10-2008 16:18 (85%)
Kruising tussen Momento Mori & Carpe diem
tja, dan moet je dat vooral doen. Maar ik denk niet dat je de PS3 veel completer kan noemen. Toegegeven, ze hebben meer platformers, maar zijn wel weer minder op het vlak van (j)rpg's. Zo heft het elkaar weer een beetje op, deze generatie zijn er gewoon 2 goede consoles met elk hun eigen voordelen die er niet enorm sterk uitspringen. Ze beginnen langzaam op elkaar te lijken, en dat is niet gek want men kijkt goed bij elkaar af. (xbox live en psn/avatars en home/arcade en ps versie etc etc)quote:alvi schreef op zaterdag 18 oktober 2008 @ 02:08:
Reg. datum: 06 augustus 2008
groetjes mzx
De j-rpg's op de 360 zijn ook niet echt geweldig. Na de ps1 vind ik 't allemaal een stuk minder geworden. Op de ps2 viel t al tegen, en deze generatie is het nog minder. Ik blijf hopen dat FF13 weer gewoon een topper wordt zoals het hoort. En dan hebben we nog The Last Remnant en White Knight Story die heel goed kunnen worden. Maar eerst zien en dan geloven.quote:DarkShadow schreef op zaterdag 18 oktober 2008 @ 13:13:tja, dan moet je dat vooral doen. Maar ik denk niet dat je de PS3 veel completer kan noemen. Toegegeven, ze hebben meer platformers, maar zijn wel weer minder op het vlak van (j)rpg's.
Reg. datum: 02 juli 2005
Ik heb speciaal voor de PS3 een DVI switch( http://www.hqproducts.com...g/page_3/artl_AVSWITCH-12 ) gekocht. Goed bekeken of me schermpje HDCP ondersteunde. DVI switch samen met me HDMI->DVI kabeltje is vandaag binnen gekomen. Meteen aangesloten en was helemaal blij dat het werkte. En de prijs viel wel mee (vind ik). 30 euro's totaal. Alleen jammer dat ik een 20 inch scherm heb en de 1080p resolutie niet werkte. Maar 720p is al super.
Jammer van LBP. Staat hier in bestelling. Word een paar extra dagen wachten dan
Nog niet veel vrienden op de PSN. Dus voeg me maar toe: Leon-MeGa.
Verschil tussen 720P en 1080P is totaal niet zichtbaar op een 20" scherm.. Zal pas echt zichtbaar zijn vanaf 37" ongeveer.. (En als de meeste mensen het dan al zienquote:MeGaSky schreef op zaterdag 18 oktober 2008 @ 16:44:
Nu ongeveer 4 weken een PS3. Geweldige console.
Ik heb speciaal voor de PS3 een DVI switch( http://www.hqproducts.com...g/page_3/artl_AVSWITCH-12 ) gekocht. Goed bekeken of me schermpje HDCP ondersteunde. DVI switch samen met me HDMI->DVI kabeltje is vandaag binnen gekomen. Meteen aangesloten en was helemaal blij dat het werkte. En de prijs viel wel mee (vind ik). 30 euro's totaal. Alleen jammer dat ik een 20 inch scherm heb en de 1080p resolutie niet werkte. Maar 720p is al super.![]()
Jammer van LBP. Staat hier in bestelling. Word een paar extra dagen wachten dan.
Inderdaad en veel mensen vergeten ook dat niet de graphics zelf worden opgepoetst, maar dat het alleen wat scherper oogt (kartelrantjes verminderen door de hogere resolutie) Een soort van anti-aliassing dus.quote:l00pz schreef op zaterdag 18 oktober 2008 @ 16:58:
Verschil tussen 720P en 1080P is totaal niet zichtbaar op een 20" scherm.. Zal pas echt zichtbaar zijn vanaf 37" ongeveer.. (En als de meeste mensen het dan al zien)
En dan bedoel ik de analog controls voor gas en remmen. Die dingen zijn gewoonweg te klein. Begin je een beetje zweethanden te krijgen, glij je constant van de R2. Bij de 360 is die wat curved en groter. Betere controle dus. Bij de PS3 controller heb ik na 10 minuten racen al kramp van de rare houding die ik aan moet nemen. Je kunt me niet wijsmaken dat anderen dit fijn vinden
Problem solved
Ik irriteer me ook mateloos (vooral bij GTA4 en paar andere demo's ) , das gewoon ****. Achja maar ze hebben iig wel een oplossing voor.
FireBladeX wijzigde dit bericht 18-10-2008 22:33 (35%)
Bron: 160 GB Ps3 Pack
Aha! Thanks!quote:FireBladeX schreef op zaterdag 18 oktober 2008 @ 22:08:
Gioteck real triggers
Problem solved
Daar ga ik eens naar op zoek.
Bedankt voor het melden, ik een klant hier heel blij mee gemaaktquote:ymmv schreef op vrijdag 17 oktober 2008 @ 22:38:
Er zit in firmware 2.5 een herstelmenu om problemen met je PS3 te fixen. Je komt er door de powerknop ingedrukt te houden bij het starten. Na 1 piep en daarna 2 piepjes krijg je dit in beeld:
Geen last van, juist met een 360 neem ik steeds andere knoppen mee?quote:Fietsbel schreef op zaterdag 18 oktober 2008 @ 22:04:
Klopt ik deel je mening
Wenn ist das Nunstruck git und Slotermeyer? Ja!... Beiherhund das Oder die Flipperwaldt gersput! The price of freedom is eternal vigilance
Leuk zo`n pakket... alleen jammer dat het gevuld is met enkele niet volledige games (GT5 = 'demo', Ratchet & Clank = mini-avontuur van paar uurtjes)quote:Mojo666 schreef op zaterdag 18 oktober 2008 @ 22:24:
De inhoud van de 160 GB packet is bekend:Ratchet & Clank: Quest of Booty, Last Guy, Gran Torismo 5: Prologue en Super Stardust HD. Toch wel leuke packet, al had ik wel liever gezien dat je zelf kon bepalen welke psn-games je wilt, doormiddel van een tegoed.
WipeOut HD was een mooie titel geweest voor het pakket...
Zet- en drukfouten voorbehouden. Niet eens met een reactie/slotje of gewoon een vraag? DM staat altijd open!
Reply was in ieder geval bedoeld voor dit bericht:
"maandag worden er europese keys voor killzone 2 beta weggegeven op ign... dus lekker f5'en daar", geplaatst door El_V
Niet KZ2 keys, maar R2 keys...quote:l00pz schreef op zondag 19 oktober 2008 @ 01:06:
Hmm de "Edit" noch "Quote" functie werken niet op dit moment..
PSN ID: blu-fox
Daarom moet je ook de GT3/4/prologue settings nemen: sturen met linkerpookje, gas/rem met rechterpookje. Ook nog precieser en nooit kramp.quote:UltraSub schreef op zaterdag 18 oktober 2008 @ 21:59:
Man man, wat is die PS3 controller vergeleken met de 360 controller butt voor racing.
* EfBe die overigens bij de 360 controller juist last van zn vingers krijgt door die R/L2 triggers
Ik heb die triggers ook, maar ik gebruik ze momenteel niet eens meer...quote:FireBladeX schreef op zaterdag 18 oktober 2008 @ 22:08:
Problem solved( klik op plaatje, wordt je doorgestuurd naar play.com met het betreffende product
PSN id: NL_SToRM
Gas/rem met rechterpookje is niet hetzelfde. Dan kun je niet remmen en gas geven tegelijk. En ja, dat gebruik ik regelmatig, al is het alleen al voor drift control.quote:EfBe schreef op zondag 19 oktober 2008 @ 10:25:
idd sorry was in de war, had namelijk ook net gelezen dat je mee dingt voor killzone 2 beta als je dat multiplayer thema download.quote:
ik persoonlijk heb er totaal geen last van, misschien omdat ik altijd playstation controller gewend ben? maar sommige vrienden van mij hebben dit probleem ook, meeste heb ook een xbox.. dus is denk ik net wat je gewend bentquote:Fietsbel schreef op zaterdag 18 oktober 2008 @ 22:04:
Ook waar. Maar ik had het over racing games. Waar bij je de triggers als analog control gebruikt.quote:-RazieL- schreef op zondag 19 oktober 2008 @ 16:49:
Als Streetfighter4 uitkomt ben ik dolgelukkig met mn ps3-controller. Ik heb m al gespeeld met de 360-controller, wat een drama is die d-pad.
Ga je mond spoelen.quote:Michael Knight schreef op zaterdag 18 oktober 2008 @ 23:47:
Dat had een mooie geweest jah...quote:WipeOut HD was een mooie titel geweest voor het pakket...
Spoelt..quote:swopdark schreef op zondag 19 oktober 2008 @ 18:04:
Ga je mond spoelen.
En nog ist geen volledige game, maar dat gaf ik al duidelijk aan... en demo nuanceerde ik nog met aanhalingstekens.
Maar zo`n 'groots' pakket, moet je ook echt groots aanpakken... doe dan beide delen van Ratchet & Clank erbij of stop er dan ook Burnout Paradise bij oid...
Burnout Paradise is geen Sony-titel. R&C:ToD is geen PSN-titel en het is een PSN-pack. Ik kan me voorstellen dat ze zouden kiezen tussen Wipe-out en GT5, maar GT5 is stukje populairder dus dat zal de reden wel zijn.quote:Michael Knight schreef op zondag 19 oktober 2008 @ 18:59:
Spoelt..![]()
The last guy snap ik niet. Hadden ze beter PJM toe kunnen voegen. Daar zitten denk ik meer mensen op te wachten en zijn ongeveer even duur.
Shiver23 wijzigde dit bericht 19-10-2008 19:24 (10%)
PSN: Shiver23 //
Heb je dat ergens gelezen? Ik wacht ook op dat pack om een ps3 aan te schaffen. (omdat lbp los vrij duur is, en 400 euro voor dat pack mij gewoon veel meer value for money geeft).quote:dialMforMike schreef op zondag 19 oktober 2008 @ 18:56:
Uitstel LBP-pack lijkt ook weer niet overdreven te worden, dus keuze wordt er niet makkelijker op.
Daarnaast is 80GB voor mij zeker meer dan genoeg. PSN games zijn (meestal) klein (muv burnout, Wipeout en dat vlieg/schiet spel waar ik nu even niet op kan komen)
Demo's worden meestal toch inactief (of die speel je eens en wis je dan, meestal toch maar één level en dat heb je snel gezien). Filmpjes ed idem. Niet elk spel heeft trouwens een install nodig, voorlopig is dat volgens mij een minderheid.
Stel nu nog dat elke game een 4-5 tal GB installeert, dan zijn dat nog steeds 18-12 games, of anders gezegd, minstens 500 euro aan games. Denk dat dit wel moet volstaan
Agree.. Ik heb hem sinds een paar dagen, en het is zeker geen Forza 2. Ik snap niet dat mensen vinden dat GT5: Proloque een betere game is dan Forza 2quote:Michael Knight schreef op zondag 19 oktober 2008 @ 18:59:
Spoelt..![]()
Je hoort me niet zeggen dat een slechte game is, maar ik snap nu wel waarom Microsoft heeft gezegd de 360 als racer console neer te willen zetten. Met het niveua van racegames op de PS3, is dat easy peasy imo.
En nee, ik zeg niet dat de 360 beter is. Ik heb ze niet voor niets allebei, en ik denk er serieus over de 360 te verkopen, omdat ik gewoon teveel consoles heb. Tot op heden krijg ik het echter niet voor elkaar om hem op marktplaats te zetten, omdat de PS3 me nog niet heeft overtuigd me het spelgenot te kunnen bieden dat ik op de 360 had.
* UltraSub is race gamert.. vandaar..
Nergens gelezen of een bron om te quoten helaas, ik baseer mijn gedachte op de 4 dagen vertraging die op de frontpage van Tweakers (en hier in de LBP thread) genoemd wordt ivm met de release van de (losse) game. Ik neig ook nog steeds meer richting de LBP pack, doos ziet er mooier uit (oog wil ook wat), maar de 160GB heeft ook zo zijn voordelen, mocht die pack toch eerder in de winkels liggen dan moet ik nog zien wat ik kies.quote:alvi schreef op zondag 19 oktober 2008 @ 19:52:
bedoel je warhawkquote:alvi schreef op zondag 19 oktober 2008 @ 19:52:
Ik heb de PS3 sinds het begin en ik heb dus de 60Gb versie. Er is ruimte zat! Vergeet namelijk niet dat niet élke game een installatie vereist. Demo's download je en speel je tot de volledige game in de winkels ligt en dan verwijder je ze.quote:dialMforMike schreef op zondag 19 oktober 2008 @ 18:56:
Lastig. Had mijn portemonnee al in LBP-pack modus gezet, maar de 160GB versie met PSN games lijkt me ook weer een mooie optie. Heb via marktplaats al GT5:P gekocht, maar die zal ik, zonder veel verlies, ook wel weer kwijt kunnen raken. Rest mij de stupide, en ook nog eens erg subjectieve en persoons/situatiegebonden, vraag: zal 80GB genoeg zijn voor +/- 10 spellen + een handvol PSN games en demo's? Of is 160GB toch meer dan wenselijk? Ik snap dat ik er een eigen schijf in kan zetten, maar indien ik dat kan voorkomen vind ik het best (gemak > moeite). Uitstel LBP-pack lijkt ook weer niet overdreven te worden, dus keuze wordt er niet makkelijker op.
Het moment dat je in ruimte nood komt, kun je de oude of reeds verkochte games weer verwijderen van de harde schijf.
Ja, je zal zo nu en dan eens moeten opruimen, maar ruimte tekort, geloof ik echt niet aan.
Het hele verhaal van de PS3 die games installeert op je HDD is wereldwijd op het internet zwaar overdreven neergezet. Natuurlijk ben je een paar gig kwijt maar absoluut niet zo heel veel als dat sommige mensen je willen laten geloven. met een 80 gig versie zit je nog ruim in de opslag na 10 demo's en 10 games.quote:dialMforMike schreef op zondag 19 oktober 2008 @ 18:56:
Een demo weegt gemiddeld 1 gig. Er zijn uitschieters met files van 1,8 of 1,6 gig maar ook kleinere van slechts 600 mb. al met al zal je de meeste demo's niet oneindig op je HDD laten staan waardoor je er misschien een stuk of 10 gemiddeld hebt staan. Dus 10 gig aan demo's
Het lijkt nodig te zeggen: Niet alle games hebben een installatie nodig. Wel hebben veel games een soort data bestand dat soms wel 300 - 500mb zwaar is incl patch of updates. Daarnaast zijn de meeste games met een verplichte installaties ongeveer 3 gig zwaar.
SITUATIESCHETS:
Ik heb een 60 gig PS3 en heb de volgende spellen:
- Call of Duty 4
- MGS4
- GT Prologue (op de HDD)
- WipeOut HD (op de HDD)
- Uncharted
- Heavenly Sword
- GTA 4
- Super Stardust (op de HDD)
- Dark Mist (op de HDD)
- WarHawk (op de HDD)
- Pixeljunk: Monsters (op de HDD)
- Pixeljunk: Eden (op de HDD)
- Viking: Battle of Asgard
- Battlefield: Bad Company
- Resistance
- Motorstorm
Zeker 4 demo's op de HDD
Al met al een aantal spellen op Blu ray en en aantal op de HDD. Daarnaast ook nog zo'n 40 albums op MP3 en nog heb ik 25 gig aan ruimte over.
Wat ik probeer te schetsen: Met een 80 gig uitvoering ben je helemaal klaar en hoef je je voorlopig geen zorgen te maken over ruimtegebrek.
swopdark wijzigde dit bericht 19-10-2008 21:35 (0%)
Reden: warhawk toegevoegt
Reg. datum: 23 augustus 2004
Dat jij met minder toe kan, wil niet zeggen dat dat voor iedereen moet gelden.
PS3 games: 23 and counting... PSN: Chrisboers Now playing: Burnout Paradise, Prince of Persia, Tomb Raider, Endwar
Nee, jij hebt de HD vervangen omdat je de ruimte nodig had. Dat lijkt me de logische werkwijze tenminstequote:chrisboers schreef op zondag 19 oktober 2008 @ 21:57:
Goh, ik heb mijn 40 GB HDD vervangen door een 320 GB, en die staat toch echt al half vol... Ja, het KAN met minder, maar als je ruimte hebt, ga je die ook gebruiken.
Maar het is idd net waarvoor je de PS3 wilt gebruiken. Is het alleen voor spellen heb je aan 40/60/80 GB naar mijn mening meer dan voldoende ruimte. Wil je hem echt als mediacenter gebruiken zonder NAS in je netwerk op te nemen heb je natuurlijk meer ruimte nodig om al je audio/video/foto materiaal kwijt te kunnen.
Last.fm | Mijn DVD-collectie | Kawasaki ZX7R
Reg. datum: 14 april 2007
Marc187 wijzigde dit bericht 19-10-2008 22:47 (99%)
Reden: foutje
Ik moest vandaag weer wat demo's verwijderen van mijn hhd om een spelupdate down te loaden, Ze zijn zo vol die hdd's . komt ook omda ik veel demo's bewaar want mn zoontje speelt ze regelmatig.
Binnenkort denk ik toch maar een 500 halen
Die HD kun je zo zonder al te veel poespas vervangen?quote:chrisboers schreef op zondag 19 oktober 2008 @ 21:57:
Hoe formatteer je dat ding dan?
Reg. datum: 18 oktober 2004
Vervangen kost nog geen 5 minuten (niet overdreven) en formatteren doet de PS3 zelf. Wel even je data back up-en op een USB stick (er is een back up functie in het PS3 menu).quote:Snowwie schreef op maandag 20 oktober 2008 @ 02:24:
Easy-peasy
"What I lack in constraints, I make up for in remorse"
Maar daar is genoeg over te vinden op het internet.
Edit: zie hierboven.
!null wijzigde dit bericht 20-10-2008 09:05 (9%)
Op reis: www.lovetheworld.nl
Reg. datum: 02 augustus 2003
Tot je er HD films op gaat zetten van 5-10gb per stuk...quote:swopdark schreef op zondag 19 oktober 2008 @ 21:33:
Reg. datum: 06 maart 2007
Even een vraag wat betreft netwerk. Als ik het goed begrijp kan je hem zowel draadloos, als via UTP aansluiten.
Wat zijn jullie ervaringen met beide mogelijkheden? Wat heeft de voorkeur?
Maar bedraad zal altijd beter en sneller blijven, dus als het makkelijk is, draadje leggen.
Dacht ik ook al ja. Zie ook niet echt een voordeel in draadloos (behalve dan weer een draadje minder in mijn meubelquote:GreenSky schreef op maandag 20 oktober 2008 @ 09:57:
Ik gebruik em draadloos, gaat prima met online gamen. Ook wel betrouwbaar.
Reg. datum: 30 juli 2008
Kan je alleen streamen via een Ad-Hoc verbinding dan? Anders maakt het toch niet uit. Laptop en PS3 zijn verbonden via de Switch/routerquote:Mj2sL schreef op maandag 20 oktober 2008 @ 10:26:
Nou, de wifi is naast het gamen ook handig om bijvoorbeeld dingetjes van je laptopje te streamen. Of als je de PS3 even ergens anders kwijt moet waar een draadje onhandig is.
Eh sorry dat is onzin. Zolang je PS3 en laptop in hetzelfde netwerk zitten (wat bij praktisch iedereen zo is in thuis situatie) dan kunnen ze elkaar gewoon vinden. Of de 1 nou draadloos verbonden is en de ander met een kabeltje maakt niet uit.quote:Mj2sL schreef op maandag 20 oktober 2008 @ 10:26:
Copywight 2000,2001,2002,2003,2004,2005,2006,2007 Arx. All wights wesewved. | PS Network tag -> Arx_nl
Reg. datum: 18 november 2004
Onze TV is geen nieuwe, heeft dus geen HDMI of component. Ik sluit die dan gewoon aan met de bijgeleverde kabel, composiet? In de begin post staat dat je dan best aansluit via RGB-Scart, maar ze zit toch geen scart connector op de PS3?
Anyway: ==> Arx in "Het PlayStation 3 ervaringen topic - Dee..." <==
'Multiple exclamation marks,' he went on, shaking his head, 'are a sure sign of a diseased mind'
Pagina: 1 2 3 4 5 6 7 8 9 10 11 last
