Dit zit erbij (zonder de cube danquote:tvhouwel schreef op donderdag 31 juli 2008 @ 11:42:
aha, nee die cubes moet ik dan ook niet hebben.
Dus de Artemis_Touch_4.02_Full_with_no_cube rom is verder een gewone normaal uitziende wm6 rom?
Ik ga vandaag eens wat handleidingen uitprinten en dan doe ik het zondag maar. Dan is het niet zo'n ramp als mijn gsm het een tijdje niet doet.
quote:HTC TouchFlo Cube 4 SIDED and bioscroll [NEW] - with touch activation of the cube. (press downward from point shown on image to activate) or press and hold until second buzz start key. - You can change cube activation settings via \settings\system\TouchFLO
Photo screen mapped to HTC Album
Video screen mapped to Core Player
HTC Home plugin 2.1.1005.722 [UPDATED] - 6 tabs enabled, tab options in settings\home - NEW SKIN, NEW CLOCK, works with edited HH_0409_WeatherCities.xml
HTC AudioManager v 1.2.1017.717 [UPDATED] - NEW SKIN
HTC Album 1.0.1030.720 [UPDATED] Portrait by default, hbutton mapping to camera button in landscape mode.
HTC Action Screen1.0.1020.720 [UPDATED]
HTC Retouched 2 Phone Dialer - NEW SKIN
HTC 6 button Comm Manager 2.0.3.0 [UPDATED]- Color buttons from Schapps and myself.
HTC Camera 4.03
HTC Network Wizard 1.0 (Build 29982)
HTC Touch PhonePad 1.0 Build 22364 [NEW]
HTC Enlarge StartMenu 1.1.31503.1 [NEW]
WM6.1 Threaded SMS [NEW]
WM6.1 Domain enroll [NEW]
SDConfig.txt [NEW] - place in root of storage card - installs your fav cabs on flashing or hard reset
Arcsoft MMS 4.2.8.1 - sms & mms accounts are split
Office 2007 - full
Windows live 10.6.34.800 [UPDATED]
Flash Lite Player 2.1 [NEW]
WOW HD Audio equalizer [NEW]
Adobe Reader LE
GroupSMS 1.1 [NEW] - send multiple texts
HTC Taskmanager V2.0 (Build 31261) [UPDATED]
Kaiser enhanced wmp skin - tweaked by myself.
Pocket ContactManager v0.11b
Black Dymond keyboard
Pocket Core Media Player 0.72 RC1- avi files associated
XnView Pocket 1.40
1-Calc Lite replaces ms calculator - [UPDATED] New touch skin and icon - thanks bigix1
Esmertec jbed build 20070802.2.1 midlets run fullscreen! [UPDATED] From Wm6.1 Kaiser rom
Mobile Secretary
Total Commander V2.5
Cyberon Voice Speed Dial black version 1.2 Build 070612
Notem v1.21 - mp3 voice recorder and mp3 to wav convertor - IMO better than orig or htc voice recorder.
Widows Live Search 2.5 - [UPDATED] a must have IMO - works with GPS
Visual GPSce v1.2 106 - mapped to gps button
Cleartemp v0.9.9 [UPDATED]
Closeall
Hibernate v1.40
BtIO v0.5 - bluetooth icon in tray on today screen - press and hold for options.
Notepad v 4.0.10 - txt and ini files associated.
PocketRAR v3.71 - fully integrated into windows, IAZip removed.
Pim Backup v 2.8.0.0. [UPDATED]
SAPSettings
Sim Manager v6.38 [UPDATED]
Synchrotime v0.93
Task Manager v2.8 - registry files associated
WM5torage v1.80 [UPDATED]
Kevtris 2.0
Freecell
Minesweeper - tweaked version
Transcriber
BatteryStatus 0.04 - bug free
TodayAgenda v 1.1 Build 3249 [UPDATED]
TFLOSettings v1.0 - Thanks to tom and nncuong [NEW]
PeekPocket 1.5 [UPDATED]
Schap's Advanced config tool 2.1.0.0 [UPDATED] - awesome config tool!
Opera mini 4.1 - install by jar (attached) - direct shortcut made - mapped to internet button [NEW]
Hbutton 2.2 [UPDATED] Startmenu button, ok\close button and camera mapped to hbutton in full version
Startmenu button
1st press = start menu
1st vibrate (hold button down) = mouse
2nd vibrate = cube
Ok\close button
1st press = close app
1st vibrate (hold button down) = closeall apps
2nd vibrate = hibernate to release even more memory.
Camera button
1st press = activate camera
2nd press = activate htc album in landscape mode.
ALSO
1. GPRS disconnect button added to data connection bubble
2. Windows media plays in standby mode
3. Security check disabled
4. Many icons added/updated
5. Edge icon enabled
With cube
45mb total storage memory
25mb free program memory
Without cube
46mb total storage memory
26mb free program memory
Wau wau!
