Hoofdcategorieën
Topicacties
[MacBook] Discussietopic en Mini-FAQ deel 11
Pagina: 1 2 3 4 5 6 7 8 9 10 11 12 ... 39 40 41 42 last
Nieuw Topic
Reg. datum: 21 juli 2006
quote:
Geqxon schreef op maandag 25 februari 2008 @ 15:19:
In mijn AppleCare zat:
-TechTools CD, heb je niet veel aan
-Serienummer
-Boekje.
Registratie van het serienummer gaat via Apple.com.
bedankt, ik heb een filmpje op Youtube gevonden "Unboxing Applecare" waar je inderdaad ziet wat er in zit.
Waar blijft de zomer nou?
quote:
We had originally published a belief that the MacBook Pro updates would be seen this Tuesday, based on information that Apple had started shipping new products to their Apple retail stores. Also known is that Best Buy inventory now shows new model numbers (MB402LL/A, MB403LL/A, and MB404LL/A) at existing MacBook Pro prices. As a result, all signs seem to point to MacBook Pro revisions on Tuesday.... however, we reworded our original story due to conflicting reports that the new products to be released on Tuesday will not be MacBook Pros.
Instead, there's been evidence that the MacBook alone will see minor revisions tomorrow.
This goes against common sense and all expectations as the MacBook has been recently revised in November of last year. Still, the information has given us enough pause to post this as a Page 2 item. While we generally avoid posting 11th hour predictions such as this, if this turns out to be true, it will also validate some additional information from the same source about the unreleased MacBook Pro updates.
Bron: Macrumors
Mac Mini C2D 1,83 GHz, 1GB mem
Update:
quote:
More evidence from (reportedly) a Canadian reseller (prices in Candian dollars). Mid range MB403LL/A is described as MacBook (MACB) and sells for Candaian $1349.99, $100 cheaper than the current midrange MacBook.
En:
quote:
MacBooks AND MacBook Pros?
A final Page 2 rumor in the hours before Tuesday. GeekSugar claims both MacBooks and MacBook Pros will be seen tomorrow.
Both will look the exact same (unfortunately no pretty new colors), although they will feature upgraded processors, additional memory, and the lovely multitouch trackpad that is featured on the Air.
GeekSugar has no known prior rumor accuracy by our records, so we are unable to gauge the credibility of their sources... however, I'll leave you with a couple of notes on this possible scenario:
- There have been conflicting reports about MacBook vs. MacBook Pro updates, leading to the ambiguity of our reports.
- An update of both product lines would neatly explain away these conflicting reports.
Klinkt erg interessant :7 Ik hou de boel in de gaten vandaag :+
-EDIT-
Sorry Daedalus, ik was een beetje te enthousiast :+ Zal niet meer gebeuren.
-EDIT 2-
Toch wil ik nog even kwijt dat de Apple store van Nieuw Zeeland momenteel wordt geupdate!
[J.d.I.] DirtyHarry wijzigde dit bericht 26-02-2008 11:22 (11%)
Keep trying
Gaan we nu de berichten van MacRumors hier copy/pasten? Dit is nog steeds het MacBook discussietopics. Geruchten en speculaties horen hier niet thuis, tenzij er 3 onafhankelijke bronnen zijn. Laten we het houden bij het delen van ervaringen met de MacBook.
“Gee Brain, what do you want to do tonight?”
“The same thing we do every night, Pinky – Try to take over the world!”
| nu met 214 avatars! | Icarus@IRC | 宇多田ヒカル \o/ |
Reg. datum: 26 juni 2002
Even een vraagje over het geheugen van de macbook.
Is er een specifieke reden dat apple het geheugen van hun zo duur verkopen?
280 euro voor 2x 1gb vind ik bizar duur als je voor 50euro(of minder) klaar kan zijn met 2x 1gb Kingston.
Zal het qua prestatie nog uitmaken welk geheugen je neemt?
Ben moet ik zeggen zeer te vreden met m'n macbook. 1 van de pluspunten vind ik de compactheid en de lange levensduur van de batterij!
Keep trying
Het antwoord op je vraag staat notabene in de topicstart en FAQ: MacBook.
Roll on!
@irongangster: simpel. De reden is winst maken. Daarom halen de meeste wat handigere Apple gebruikers hun RAM gewoon bij de PC boer. Zie ook [Geheugen] Geheugen upgrade tips & weetjes
Qua prestaties zal het niet uitmaken aangezien het in alle gevallen om PC5300 CL5 geheugen gaat. Geheugen met andere CL lijkt problemen te geven.
"Conclusion is the point where someone got tired of thinking"
Ja omg.. heb ik net een nieuwe macbook besteld voor iemand.. (gister).. gaan ze em nu waarschijnlijk updaten :(
Kan ik em dan nog laten omruilen of?.. hoe gaat de apple store daarmee om? Kan de sales_policie niet lezen want ze zijn de apple store aant updaten.
quote:
Daedalus schreef op dinsdag 26 februari 2008 @ 11:57:
Is dat zo? Ik had dit al gelezen inderdaad.
"Als ik extra geheugen bestel is het zo enorm duur! Kan dit niet goedkoper?
Tuurlijk kan dat goedkoper! Ik heb zelf ook mijn geheugen zelf ingebouwd.
Kijk gewoon even op de pricewatch! Let wel op dat je MacBook standaard 2 reepjes van 256 MB heeft. Dus als je los geheugen koopt, moet je eerst een reepje eruit halen. Het is helaas dus niet zo, dat als er er 1 GB bijkoopt, je 1,5 GB hebt."
Ik lees hier niks over de reden dat de Apple geheugenreepjes zo knetterduur zijn?
Ook staat hier niks over de kwaliteit dus ik denk dat mijn vraag "mag"...
Reg. datum: 13 juli 2006
quote:
Daedalus schreef op dinsdag 26 februari 2008 @ 10:33:
[mbr]Gaan we nu de berichten van MacRumors hier copy/pasten? Dit is nog steeds het MacBook discussietopics. Geruchten en speculaties horen hier niet thuis, tenzij er 3 onafhankelijke bronnen zijn. Laten we het houden bij het delen van ervaringen met de MacBook.[/]
Hee wat vreemd zeg, de store is down.
monkey is gone to heaven
quote:
irongangster schreef op dinsdag 26 februari 2008 @ 12:11:
Als het goed is wel. Als je MacBook nog niet verzonden is krijg je al de nieuwe.
Misschien is het een troost voor jou: Ik heb vanochtend een MacBook ontvangen en hoop maar dat ik het kan om ruilen. Maar volgens mij zijn ze best oké bij Apple.
20" Cinema Display / 13" MacBook black / 3.5" iPhone 3G Wit / last.fm
De store is down, dus zometeen zal wel duidelijk zijn wat er nieuw is :).
Canon 40D - Canon 17-40 f/4L - Canon 70-200 f/4L - Canon 50 1,8 II - Canon BG-E2N
Roll on!
quote:
super-muffin schreef op dinsdag 26 februari 2008 @ 12:25:
Of Apple nu oke is of niet; volgende uit de wet voor Koop op Afstand heb je het recht om binnen 14 dagen kosteloos zonder opgaaf van reden het product terug te sturen. Je krijgt dan je volledige aankoopbedrag terug.
quote:
RoelJewel schreef op dinsdag 26 februari 2008 @ 12:29:
Er zijn mensen die de nieuwe MacBook al in hun handen hebben gehad. Dus het lijkt me meer dan duidelijk dat er nieuwe MacBooks komen. Ze zijn er, alleen nog niet op de store. BTW alle stores zijn zo'n beetje down dus dat wil zeggen dat er iets groots komt.
Toen hij dat postte waren het nog puur geruchten en waren de stores nog up ;) Nu liggen wereldwijd alle Apple stores plat, dus er staat wat groots aan te komen. We zullen over 1 of 2 uurtjes wel zien wat voor moois er te koop is :9
Reg. datum: 04 december 2005
Had afgelopen vrijdag ook zwarte macbook besteld, maar was vandaag nog steeds niet verzonden, dus ff gebeld uiteraard (wetende van alle rumors). Een update kon de reden zijn dat die nog niet verzonden was, maar mocht de wel verzonden zijn, en komt er wel een update, dan kun je tot 14 dagen na aankoop (of ontvangst, dat weet ik niet) je macbook terugsturen om voor een nieuwe om te laten ruilen. Geen probleem dus je upgrade te krijgen als die komt :)
Keep trying
quote:
irongangster schreef op dinsdag 26 februari 2008 @ 12:15:
Wat er staat is dat goedkoper kan. Er dus geen reden om speciaal het dure geheugen van Apple te nemen, aangezien het niet uitmaakt.
Reg. datum: 10 juni 2003
oei, standaard 2 gig en 2.4 Ghz voor mid en blackbook
Chriztiaan wijzigde dit bericht 26-02-2008 14:36 (3%)
MacBook C2D 2.2 Ghz 4GB Ram
Ok, snellere cpu's (penryn?), meer geheugen voor de twee duurste modellen. Alle modellen een grotere HD. Wel nog steeds een combodrive :r in het basismodel :( En is de apple remote er nou uit gehaald? :?
Wel een prijsdaling :) maar dat mag ook wel met de huidige dollarkoers :7
[J.d.I.] DirtyHarry wijzigde dit bericht 26-02-2008 14:58 (8%)
Reg. datum: 04 april 2007
Prachtige update!!
zie hier:
(de midbook, weeral de interessantste)
2,4-GHz Intel Core 2 Duo
3 MB gedeelde L2-cache
=> 3MB cache= Penryn=> zuiniger& SSE4! en nog een snelle ook!
DUAL channel 2 GB RAM (werkt sneller dan MBP instap!)
Wat mis ik nu??
LED verlichting?
ATi GPU?
PS: als je hem besteld, vergeet niet de apple remote en de vga convertor, kom je uit op 1239
g4wx3 wijzigde dit bericht 26-02-2008 14:59 (3%)
Me OS X
Ben ik toch nog mooi blij met m'n goedkoopste model voor 880 euro met zelf 2GB RAM en een 7200rpm schijf ingebouwd. Ik mis in ieder geval niets van wat de nieuwe modellen nu hebben. :)
* Iemand nog suggesties?
Reg. datum: 19 mei 2007
Mooie update dit hoor. Ik heb het Santa Roza model net 4 maanden dus ik moet nog even wachten om te updaten :). Als je een macbook wilt kopen zou ik het nu doen!
Ben nu al benieuwd naar hoe lang deze machientjes doen met een accu :)
Ik zie trouwens dat de Apple remote er WEL bij zit, schijnbaar vinden ze het inmiddels vanzelfsprekend ofzo dat ze er geen reclame meer mee maken.
Roll on!
quote:
[J.d.I.] DirtyHarry schreef op dinsdag 26 februari 2008 @ 15:02:
Heb je een linkje waar je dat ziet dan? Op de specs pagina's op apple.com staat het in elk geval niet; daar staat de Remote enkel als optie.
Keep trying
Remote zit er dus niet meer bij:
What’s in the box
  • MacBook
  • Display cleaning cloth
  • 60W MagSafe Power Adapter, AC wall plug, and power cord
  • Lithium-polymer battery
  • Install/restore DVDs
  • Printed and electronic documentation
De specificaties zoals die nu op de Nederlandse website staan, zijn van de vorige versie.
VNU Media logo Powered by True
© 1998 - 2008 Tweakers.net - Alle rechten voorbehouden
Uitgever van:
