I don't know who this guy is, but I want him and his tortilla's ... DEAD !
[Discussie] AMD Sempron, Athlon 64 & Opteron - Deel 16
Pagina: 1 2 3 4 5 6 7 8 9 10 11 12 ... 18 19 20 21 last
Nieuw TopicWeer meer slecht nieuws. Ik had toch meer iets van 65 watt verwacht voor die clockspeeds. En met de B2 45 watt. Want anders kunnen ze niet met intel concurreren want die vaan ook quad cores van rond de 40-50 watt uitbrengen.quote:Not that great
We learned that Barcelona, Opteron 2200 series at its launch 1.9 GHz will have the TDP of 95W. We are talking about the B1 stepping version that will be the first to launch.
There will be a second iteration of Barcelona stepping known as B2 (ba) stepping and this one is suppose to have the lower voltage and will be able to hit the higher speeds.
K10 B2 (ba) stepping is the one that can go over 3GHz and we hope that we can see it this year.
Sys -=System Specs=- -LET OP!!! dyslectisch Dus spelling kan verkeerd zijn!!!- 3DMark 2003 Score = 30869
high-end: 120W
performance: 95W
he en dual core: 68W
be en sempron: 45W
Er zouden toch ook Opteron HE's komen van 65 en 45 watt die wel 4 cores hadden ? Want intel is daar ook druk mee bezig. Maar ik kan me vergissen ?quote:Hacku schreef op dinsdag 28 augustus 2007 @ 11:37:
Dat is geen nieuws, die tdp's zijn al lang bekend.
high-end: 120W
performance: 95W
be en sempron: 45W
Reg. datum: 27 november 2005
zit er dus eentje op XS met dit bord maar zonder cpuquote:
waar ik me vooral in intresseer is de socket koeling
maar ook een flinke 12 phase voeding voor de cpu
AMD makes big comeback in U.S. retail:
"According to the market research firm, AMD-based desktop and notebook PCs achieved a unit share of 51.0% in July in U.S retail: Compared to June 2007, the company was able to steal 13.4 points from Intel; AMD's share was also up 4.3 points year over year from 46.7% in July of 2006.
This jump in market share comes somewhat unexpected, but was explained by Current Analysis through the firm's aggressive processor pricing."
The Common System Interface: Intel's Future Interconnect :
"....an extremely in-depth report that is the work of roughly 5 months of research, studying Intel's patent disclosures. In this article, I describe CSI is exquisite detail, including the physical layer, link layer, coherency protocol and I provide some speculation as to how CSI will be used in future products"
CSI is Intel's aankomende systeem architectuur, die elk voordeel die AMD's platform nu "eventueel" nog heeft weg moet (gaat) poetsen. Zeg maar de tegenhanger van Hypertransport.
EaS wijzigde dit bericht 28-08-2007 14:19 (35%)
En over die share. In NL wordt er echt super veel C2D verkocht. vooral laptops. Daar is denk ik 90% intel. Als niet meer
En dat CSI is inderdaad een leuke verbetering. Ben benieuwd hoeveel baat Intel's cpu's hebben bij die bus. Want tot nu toe hebben ze bv de cash groot en snel gemaakt om die latency van die bus en de memory controller die niet on die zit weg te poetsen.
Misschien is de winst bij intel maar iets van 5%.
MAar ik denk dat het voor de desktops minder nut heeft. Maar dan zie je ook bij de huidige Athlon's Vanaf 600 MHz ( en dus hoger ) HTT merk je niets onder de 600 krijg je een kleine drop.
- 1.8 GHz @ 1.056V
- Stepping B-0
EaS wijzigde dit bericht 28-08-2007 16:03 (21%)
๏̯͡๏) Specs ๏̯͡๏) Longcat is loooooooooooooooooooooooooooooooooooooooooooooooooooooong
omdat ze de snelheid, cache etc nu van core 1 aflezenquote:leonpwner1 schreef op dinsdag 28 augustus 2007 @ 16:02:
Waarom staat er maar 1 Core?
links onder in staat een vakje processor #1, daar kan je er wss nog 3 andere selecteren
Nee, dat bedoel ik niet. Er staat: Cores: 1, Threads: 1. Bij mijn dual-core processor staat daar in beide vakjes een '2'.quote:ataky schreef op dinsdag 28 augustus 2007 @ 16:50:
Weet je wat ik nou slordig vind?quote:ataky schreef op dinsdag 28 augustus 2007 @ 13:12:
zit er dus eentje op XS met dit bord maar zonder cpu![]()
Degene die dit plaatje in elkaar heeft geflanst, wie het ook moge zijn, is vergeten de spellingscontrole uit te zetten. Dat vind ik wel een HELE domme fout, PR-onwaardig
Rosetta@Home, 'cause we are worth it!
Idd, zat ik ook al over te denkenquote:Jejking schreef op dinsdag 28 augustus 2007 @ 18:37:
http://www.theinquirer.net/default.aspx?article=41970quote:K10: meet (Beverly) Krusher to the 10th degree
By Theo Valich:
When clocked at 3.0 GHz and equipped with two overclocked HD2900XT cards in CrossFire, Agena FX or single-core Barcelona smashed an index of 30,000 3DMarks 06.
Yes, you’ve read it right - the barrier of 30,000 was passed to, barely, 30.031.
We know that there are different systems floating around, and we have no doubt that leaks will start appearing after this article goes live. Knowing what was the overclock of Kentsfield processor, Intel Yorkfield has quite a big job to do. One thing is clear, though. Intel needs Nehalem, and it needs it badly.
When running at 2.5GHz, the 3DMark06 score ended at 23.768, so we were thrilled to see such a good score coming from two 512MB cards. This showed the clear potential of this four core processor marchitecture, but the helter skelter ride happened after we overclocked the processor to 3.0GHz.
The particular processor was none other than a single socket Barcelona or Agena FX, call it what you will. The reference motherboard containing RD790 chipset packed two HD 2900XT cards, and the memory installed was Corsair’s Dominator PC2-9136C5D, or the same ones we have been using ever since they came out. There was a Raptor hard drive, and that was about that. OCZ will like the fact that PP&C Quaddie CrossFire PSU was installed in the system.
Windows Me II (Vista) Ultimate was installed as the operating system of choice. For some odd reason, the 32-bit version was installed in a system with 4GB of memory, needless to say the system detected 3.24GB, and benchmarketing commenced.
als dat nou waar is
maar na shamino en kinc is dit ook niet zo realistische
AMD Speaks On Barcelona & Phenom:quote:ataky schreef op dinsdag 28 augustus 2007 @ 19:48:
als dat nou waar is
....we had the opportunity to speak with John Freude, AMD's Worldwide Business Development Manager for Server/Workstation Products.....
John says the Quad-Core Opteron systems had already been submitted to the benchmark organizations for testing. The results are all under NDA and will only be released on launch date, September 10, 2007. Because they are under NDA, he cannot reveal the actual results, but he gave us some interesting indications of how the Barcelona will eventually fare against an equivalent Intel processor.
- 20-30% better performance overall
- 170% better performance in some benchmarks
Reg. datum: 04 april 2004
Reg. datum: 23 augustus 2007
Ik sta op dit moment voor de CPU-keus
AMD-Athlon 64x2 5200, of
Pentium DualCore. Ik heb er echt geen verstand van.
Kan iemand mij vertellen wat de beste keus zou zijn en of eer veel prijsverschil is?
Bij voorbaat veel dank!
Renee.
Ik vraag me werkelijk af wat je met zo'n quote aan moet. 170% in sommige benchmarks. Er is altijd wel een benchmark te vinden die enorm geoptimaliseerd is. Daarnaast:quote:EaS schreef op dinsdag 28 augustus 2007 @ 21:12:
• 170% better performance in some benchmarks
Dat is ook niet echt een duidelijk iets. Over welke Intel-cpu praten we dan?quote:Because they are under NDA, he cannot reveal the actual results, but he gave us some interesting indications of how the Barcelona will eventually fare against an equivalent Intel processor.
Pentium Dualcores zijn de gestripte versies van de Core 2 duo processoren. Ze hebben maar 1MB L2-cache en een FSB van 200MHz.quote:callas schreef op dinsdag 28 augustus 2007 @ 21:25:
Hallo allemaal,
Voor prijsverschil zie hier: Tweakers.net Pricewatch
Voor reviews bijvoorbeeld deze benchmark en via Google: 'E2140 benchmark'
Binnen 5 minuten genoeg reviews.
_the_crow_ wijzigde dit bericht 28-08-2007 21:35 (39%)
Schrödingers cat: In this case there are three determinate states the cat could be in: these being Alive, Dead, and Bloody Furious.
Dat kan een gelijk geklokte Xeon zijn of eentje in dezelfde TDP klasse of eentje in dezelfde prijsklasse.quote:EaS schreef op dinsdag 28 augustus 2007 @ 21:12:
Ik hoorde dat in de nieuwe 45watt CPU's BE-2350 & BE-2300 nog een bug zit omdat de C1E functie door de CPU ! niet goed gesupport wordt. AMD werkt hier nog aan, maar in sommige biossen van mainboards staat dit default al gedisabled, en dat resulteert in een crash.
In November komt het nieuwe UMA chipset van nVidia, de MCP78 met DX10 support en AM2+ / HT3, het chipset dat ook als eerst het Hybrid SLI zal supporten hierover heb ik al eerder gepost. Nu komt er rond dezelfde periode ook een nieuw discreet chipset, MCP72. Dit zal het eerst chipset zijn dat 3-way SLI support. MCP72XE doet 2x PCI-E x16 gen2 (of 1x PCI-E x16 gen2 + 2x PCI-E x8 gen2 / 4x PCI-E x8 gen2). MCP72P doet enkel 1x PCI-E x16 gen2 (of 2x PCI-E x8 gen2). Voor intel volgt ongeveer hetzelfde.
Bedankt voor de web-adresjes. Ik was net niet duidelijk genoeg.quote:Pentium Dualcores zijn de gestripte versies van de Core 2 duo processoren. Ze hebben maar 1MB L2-cache en een FSB van 200MHz.
Het gaat om Intel Core duo E6600 (die zou 4 Gh. zijn)
en de AMD Athlon 64 x 2 5200+
Ik begrijp heel weinig van al die technische specificaties, maar ik zou gewoon graag
willen weten wat volgens jullie de beste keus is, even onafhankelijk van de prijs. (die heb ik
net bekeken).
Pentium Dualcore is iets anders dan Intel Core (2) Duo, die je dus uiteindelijk bedoelde.quote:callas schreef op dinsdag 28 augustus 2007 @ 21:55:
De E6600 is beter dan de X2 5200+, maar prijs-prestatie-gezien zou ikzelf voor de 5200+ gaan (110E vs 190E).quote:Ik begrijp heel weinig van al die technische specificaties, maar ik zou gewoon graag willen weten wat volgens jullie de beste keus is, even onafhankelijk van de prijs. (die heb ik net bekeken).
4 Gh.? 4 GHz bedoel je? In dat geval: nee, de Core 2 Duo E6600 loopt op 2.4 GHz. Maar waarom naar GHz'en kijken? Dit zegt vrijwel niets over de snelheid van de cpu...quote:callas schreef op dinsdag 28 augustus 2007 @ 21:55:
net bekeken).
Ook liggen de 2 CPU's die je noemt niet echt in dezelfde prijsklasse (volgens mij). Ik zou voor een Athlon 64 5600+ X2 gaan.
Aah, o.k. zo'n eenvoudig antwoord, daar zat ik op te wachten.quote:_the_crow_ schreef op dinsdag 28 augustus 2007 @ 22:04:
Heel veel dank voor je hulp!!
