Gathering of Tweakers
Quicksearch
Alle schijn tegen
eindelijk na maanden weer een update voor newsleecher:
quote:
3.9 Beta 3 - Released 08 Jun 2007
+: Added an option to enable/disable the single-click activation
when clicking the tray icon. The option can be accessed from
the tray popup menu.
+: The Article Subject Ignore Filter (which can be accessed from
'Options->Filters->Ignore Filter') now also applies to
SuperSearch articles results and Repair'n'Extract set files.
*: The filter system has been much improved. All main filters now
support boolean searching ("and", "or", "not" search queries)
and new toolbars with subfilters makes it possible to narrow
the search queries even further if wanted.
*: Changed the functionality of the Repair'n'Extract Auto-Unpause
feature. Instead of auto unpausing *any* needed set files from
the transfer queue, it will now only auto unpause PAR repair
files. This makes it possible to manually pause files in the
transfer queue, without the RnE 'auto unpause' feature unpauses
them again.
*: The Pause Dl. Filters can now temporarily be ignored, by
holding down the F12-key on the keyboard, while adding
articles to the transfer queue.
*: When Repair'n'Extract encounters an error with a set, such as
when it's unable to extract archives due to password protection
or lack of diskspace, the exact error will now be shown in the
set 'status' listview column.
*: When using the 'Perform Action when Queue is Empty' feature,
the action will now be delayed until the transfer queue is
empty *and* all eventual jobs in the Repair'n'Extract queue
have finished:
http://www.newsleecher.com/forum/viewtopic.php?t=12636
*: Lots of smaller additions and improvements.
!: Since the previous beta, the article filters didn't always
work as they should. This has been fixed.
!: Fixed "When Empty > Run Commandline does not correctly parse
input string" bug:
http://www.newsleecher.com/forum/viewtopic.php?p=32682
!: Fixed "Post confirmation dialog chops off long subject
titles" bug:
http://www.newsleecher.com/forum/viewtopic.php?p=51238
!: Fixed bug where articles were not saved to the disk, if the
specified download folder didn't exist, and the default
download folder didn't exist either. In such case, articles
will now be saved to the '%USERPROFILE%\Downloads\' folder:
http://www.newsleecher.com/forum/viewtopic.php?p=54179#54179
!: Fixed "Resuming a partially download UUEncoded multipart
results in a failed download" bug:
http://www.newsleecher.com/forum/viewtopic.php?t=9261
!: Fixed an issue, where toolbar items sometimes were inaccessible
if the toolbar was wider than the NewsLeecher window:
http://www.newsleecher.com/forum/viewtopic.php?t=11689
!: Fixed "Explorer tab displays file sizes of large files (> 4GB)
incorrectly" bug:
http://www.newsleecher.com/forum/viewtopic.php?t=10905
!: Fixed "Exported NZBs have an incorrect codepage defined" bug:
http://www.newsleecher.com/forum/viewtopic.php?t=8210
!: Fixed bug where the Auto-Import-NZB feature sometimes would
import incomplete NZB files:
http://www.newsleecher.com/forum/viewtopic.php?t=12070
!: Fixed bug where Repair'n'Extract sometimes would delete files
which shouldn't be deleted, after having processed the set.
!: Fixed bug where NewsLeecher would sometimes hang when using the
the "When Queue is Empty > Shutdown" feature:
http://www.newsleecher.com/forum/viewtopic.php?t=13509
!: Lots of other minor bugfixes here and there.
Ha! Mooi! ik had wel eens last van deze:
Tijd om hem te downloaden.
Tnx voor de info ;)
Reg. datum: 06 augustus 2001
ik heb het idee dat bij het parren en rarren nu meer processorkracht gebruikt wordt (met de nieuwe beta nummer 3), meer mensen die ervaring?
3.9 Beta 4 - Released 12 Jun 2007
+: Added an option to 'Collapse Virtual Groups' in the 'Active
Group' dropdown menu on the main menu.
*: A few improvements and changes here and there.
!: Fixed bug where group activation didn't always work:
http://www.newsleecher.com/forum/viewtopic.php?t=13849
!: Fixed bug introduced in beta 3, where the 'Shaded Sort Column'
option was ignored:
http://www.newsleecher.com/forum/viewtopic.php?t=13846
!: Fixed character stripping bug when using the RnE 'Find in
SuperSearch' feature:
http://www.newsleecher.com/forum/viewtopic.php?t=13842
!: GUI themes didn't work since last beta. This has been fixed, but
one of the themes has been removed due to problems with the theme
painting:
!: Fixed bug where font settings were incorrect under Windows XP,
if Office 2007 had been installed:
http://www.newsleecher.com/forum/viewtopic.php?t=12613
!: Refixed bug related to toolbar items not being shown when using
low screen resolution (800x600):
http://www.newsleecher.com/forum/viewtopic.php?t=13859
!: Other small fixes.
Heren,
ik heb een probleem met de snelheid van Newsleecher. Ik kan maximaal downloaden met 300 KB/s, als ik torrents ga downloaden dan haalt hij met gemak 600 KB/s. Ik heb de instellingen van Newsleecher allemaal standaard laten staan, alleen de map waar de downloads in moeten komen te staan heb ik veranderd. Ik gebruik een Linksys wireless router WRT54G (met laatste firmware) en ook gebruik een linksys wireless netwerk card. Verder heb ik geen rare instellingen gedaan in mijn router, alleen poorten open gezet voor Torrents.
Heeft iemand een idee wat dit zou kunnen zijn.....?
Edit koning
Reg. datum: 25 februari 2002
Ik had ook al geantwoord in het andere topic, dus hier even een korte samenvoeging en een aanvulling.
Kijk hoeveel connecties je hebt. 300+K is wat ik haal met 1 connectie. Ik heb 3 connecties met tweaknews en haal dus ruim over de 900K.
Daarnaast weet ik niet wat voor verbinding je hebt, als je naast newsleecher ook die torrents heb draaien zou je lijn zomaar vol kunnen zitten.
Waar sla je je bestanden op? op een externe HD? dan zou het kunnen zijn dat die HD de beperkende factor is.
Maar aangezien die 300K ongeveer is wat ik thuis ook haal per connectie zal het wel aan het aantal connecties liggen.
Hier van de tweaknews site een handleiding hoe je tweaknews in moet stellen: http://www.tweaknews.nl/n...dleiding_newsleecher.html
Daar kom je ook een screenshot tegen voor het aantal connecties. Je kan er als het goed is maximaal 4 instellen.
job wijzigde dit bericht 14-06-2007 11:52 (28%)
Mijn Wii nummer: 0525 4728 8772 1934, graag een PM bij toevoeging
quote:
job schreef op donderdag 14 juni 2007 @ 11:45:
Hier van de tweaknews site een handleiding hoe je tweaknews in moet stellen: http://www.tweaknews.nl/?page=news/software
Bij tweaknews ben je gecapped per connectie, vandaar dat je daar dus een max snelheid haalt per connectie.
Bij andere providers is dit niet zo (bijv eweka of newsxs).
Het ligt er dus maar net aan welke payserver nickholte gebruikt.
Edit koning
Hij gebruikt tweaknews.. staat in het andere topic :)
NickNolte in "[Gebruikerservaringen] Newsleecher*"
job wijzigde dit bericht 14-06-2007 11:55 (75%)
Grappig ik heb volgens mij 8 connecties ingesteld :)
JOB,
ik heb alleen de verbinding van Tweaknews open staan en verder geen torrents. Hij wordt trouwens ook opgeslagen op de interne hdd. Ik zal vanavond thuis even kijken.
Edit koning
quote:
TheVMaster schreef op donderdag 14 juni 2007 @ 12:04:
Ohja, dat was vroeger zo :)
Tegenwoordig kan je er 8 openen.
Maarja meer dan 3 openen heeft voor mij geen zin omdat ik dan toch al op de max van m'n verbinding zit.
job wijzigde dit bericht 14-06-2007 12:08 (17%)
Het werkt met het verhogen van het aantal connecties. Ik heb hem nu op 8 connecties gezet en kan nu downloaden met 900+ kb\s.
Bedankt voor jullie hulp.
Whatever
Ik heb vandaag een verse XP install gedaan en weet niet waar het aan ligt maar als ik nu newsleecher probeer te benaderen kom ik niet op de site! Het gekke is wanneer ik de site ping ik op mijn eigen netwerk uit kom.
Ik zit achter een router en krijg bij het pingen van de site 127.0.0.1
Mijn provider is chello maar volgens mij staat dit daar helemaal los van. Iemand enig idee?
Te dom voor woorden... foutje in mijn router... mijn slechtste post ever.
Maverick2001 wijzigde dit bericht 26-06-2007 21:27 (9%)
Choose Booze
Ik word meester wapenmaker!
Heeft iemand enig idee waarom newsleecher altijd trager download dan iets anders?
Als ik bijvoorbeeld een demo van een spel download of een patch of driver dan gaat dat meestal met 600+ kb/s
Als ik iets met newsleecher download blijft het altijd onder de 300kb/s.
Ik heb 3 bots.
Mijn ISP is KPN.
Alvast bedankt!
HugoBoss1985 wijzigde dit bericht 26-06-2007 21:31 (3%)
Coolermaster CM690 | Coolermaster Realpower Pro 850 | Asus P5E | Intel Q6600 @ 3,6 | Sparkle 9800GX2 | Creative X-Fi XtremeGamer | 2 gig HyperX PC9600 D9GKX @ 800 3-3-3-8 1t | Samsung Spinpoint F1 750.
Zal wel ergens iets bij jou zijn, hier doet hij gewoon 420kb/s, de max van mijn lijntje.
Waarom zet je er niet een keer 4 lijntjes op om te kijken of dat beter gaat?
Welke usenetprovider gebruik je?
Canon EOS 400D / Sigma 17-70 f/2.8-4.5 / Canon 50mm f/1.8 II / Tamron 55-200 f/4-5.6
Zet jezelf op de kaart met TweakerMaps
news.kpnplanet.nl
Ik zal dat eens proberen.
Oké ik had dat gedaan, maar dan komt er bij de 4de bot te staan "UNABLE TO LOGON SERVER RESPONSE 400 NEWS.KPNPLANET.NL YOUR HOST CONNECTION LIMIT REACHED NEWSMASTER(AT)PLANET.NL
HugoBoss1985 wijzigde dit bericht 26-06-2007 22:02 (66%)
Ok, je wordt dus gecapped op 3 lijntjes door kpn. Aangezien je de newsserver van je isp gebruikt, zou het mij niet verwonderen als dat de max snelheid is die je kan krijgen.
Maar daar zullen je Nederlandse medemensen je beter kunnen over informeren. :)
Professioneel azijnpisser
Kunnen connectie gerelateerde vragen niet beter verhuizen naar Newsservers met binaries [deel 6] ?
Aangezien dit soort dingen IMHO nooit aan newsleecher zullen liggen.
Helemaal juist, maar dat wist Hugo natuurlijk niet, aangezien hij vroeg waarom Newsleecher trager was dan andere bronnen. ;)
Dankjewel :)
Ik zoek het ergens anders dan wel op :(
quote:
HugoBoss1985 schreef op dinsdag 26 juni 2007 @ 22:20:
Dankjewel :)
Ik jaag je niet weg, ik wijs je slechts naar een ander deel van het forum. Je smiley vind ik dan ook ietwat ongepast, omdat ik je slechts wil helpen.
Sorry, ik dacht dat je met die smiley alleen een sip smiley kreeg en niet een boze!
Dat was dus niet de bedoeling.
Ik ben sinds kort mijn snelheidsgrafiek die links onderin altijd staat kwijt. Ik heb al zitten zoeken maar ik krijg het niet voor elkaar om hem weer tevoorschijn te toveren.... iemand een idee waar ik deze kan zoeken?
quote:
HugoBoss1985 schreef op dinsdag 26 juni 2007 @ 22:24:
Dan duw je toch op de editknop :S
Ik heb 3.9b6 geďnstalleerd. Als ik daarin RnE gebruik, dan vreet dat zoveel geheugen dat mijn VMware-sessie eruit klapt.
Iemand meer problemen met het geheugen vreten van beta 6? T/m beta 5 had ik dit probleem niet.
© 1998-2008 Tweakers.net BV - Based on React - Hosted by True - Served by Astraeus
[RSS][XML]
Update Tracker
Active Topics
Active Topics
Frontpage Nieuws
Frontpage Nieuws
